Community Member
Busy signal when dialing into ISDN modem via POTS on a 3640 Router
We are trying to figure this one out. We hooked up 4 ISDN lines to our Cisco 3640 router and when we try to make an analog call or even try dialing the number with a phone to hear what happens, we get a busy signal. We set up all the required parameters and tested an ISDN to ISDN call and had success, but not with an analog call. Any ideas to point us in the right direction? We have the latest IOS for the box, all the necessary cards, etc. Thanks for any help,
Matt
Re: Busy signal when dialing into ISDN modem via POTS on a 3640
You need a digital modems in 3640 to terminate the analog call over isdn line..Pl. make aure that you have that in 3640..After that you need to have "isdn incoming-voice modem" inder the interface serial x:23 (d channel) to punt the voice/analog call over to modem..Here is the link which have sample config for that
http://www.cisco.com/warp/public/793/access_dial/5300.html
config will be the same for 3640 too.
Now if it still dosen't work, need to know the following debug
debug isdn q931
debug modem
debug modem csm
Also need running config too..Tejal
Community Member
Thanks for the response. We do have the digital modems installed (just got those yesterday), but are still getting busy signals. Attached is our config, do you see anything out of the ordinary? These are four seperate ISDN lines. Not a T1. Thanks, Matt
Building configuration...
Current configuration : 3022 bytes
version 12.2
service timestamps debug uptime
service timestamps log uptime
service password-encryption
hostname Cisco3640
aaa new-model
aaa authentication login default group radius enable
aaa authentication ppp default group radius
aaa authorization network default group radius
aaa accounting exec default start-stop group radius
aaa accounting network default start-stop group radius
aaa accounting connection default start-stop group radius
aaa accounting system default start-stop group radius
aaa session-id common
enable password 7 09414F1A0D00051F020200
modem country mica usa
ip subnet-zero
ip name-server 192.168.1.3
ip dhcp-server 192.168.1.4
ip dhcp-server 192.168.1.3
async-bootp dns-server 192.168.1.3 12.127.16.68 12.127.17.72
async-bootp nbns-server 192.168.1.4 192.168.1.3
isdn switch-type basic-ni
interface BRI0/0
no ip address
encapsulation ppp
shutdown
isdn spid1 63073998120101 7399812
isdn spid2 63073998150101 7399815
interface Ethernet0/0
description connected to CorporateNetwork
ip address 192.168.1.20 255.255.255.0
half-duplex
interface BRI3/0
no ip address
encapsulation ppp
interface BRI3/1
no ip address
encapsulation ppp
isdn spid1 63073962570101 7396257
isdn spid2 63073962680101 7396268
interface BRI3/2
no ip address
encapsulation ppp
isdn spid1 63073962860101 7396286
isdn spid2 63073962890101 7396289
interface BRI3/3
no ip address
encapsulation ppp
isdn spid1 63073962900101 7396290
isdn spid2 63073962920101 7396292
interface Group-Async1
ip unnumbered Ethernet0/0
encapsulation ppp
ip tcp header-compression passive
no ip mroute-cache
dialer in-band
dialer idle-timeout 300
async mode interactive
peer default ip address dhcp
ppp authentication ms-chap
group-range 35 44
interface Dialer1
no ip address
encapsulation ppp
no keepalive
dialer in-band
dialer-group 1
ppp multilink
ip classless
ip route 0.0.0.0 0.0.0.0 192.168.1.25
ip http server
ip pim bidir-enable
dialer-list 1 protocol ip permit
snmp-server community public RO
snmp-server location Lemont
snmp-server contact Jason westpfahl,630-605-0635,jwestpfahl@clippergroup.com
radius-server host 192.168.1.4 auth-port 1645 acct-port 1646
radius-server retransmit 10
radius-server key 7 070C285F4D06
line con 0
exec-timeout 0 0
password 7 070C2C4D450C0B
line 33 34
modem Dialin
transport input all
autoselect during-login
autoselect ppp
line 35 44
modem Dialin
transport input all
autoselect ppp
line aux 0
line vty 0 4
end
The config looks OK...We need to know that the analog call is even forwarded over bri line to the router (3600) or not..Need to see the following debug now for a analog call dialin over BRI line.
debug isdn q931
debug modem
debug modem csm
debug ppp negotiation
term mon
Also there is a sample config along with troubleshooting info for your refereance..
http://www.cisco.com/warp/public/471/bri_3640.html
429
