07-20-2002 07:24 AM - edited 03-02-2019 12:02 AM
before creating vlan interface or assign a port to a vlan
07-20-2002 07:36 AM
Yes, you need to create VLAN using either config-vlan Mode or the VLAN databse. You can find more info on CCO at
http://cio.cisco.com/univercd/cc/td/doc/product/lan/c3550/1219ea1/3550scg/swvlan.htm#xtocid7
07-20-2002 11:17 AM
You can only define 1-1005 in the vlan database. to define extended vlan range upto 4096, use the configuration mode vlan commands
07-20-2002 05:27 PM
thks
btw,3550-smi support layer-3 switching?
07-20-2002 05:32 PM
You'll need the EMI image for Layer 3 features
