Webcast-Catalyst9k
C2950 power comsumption
hello
can you tel me what is the reel power consumption in function of the number of devices connected for the C2940, the data sheet gives only the max of 15 W
1 REPLY
Re: C2950 power comsumption
I think as the document says the maximum value is 15W. You can also set it manually to any value within 15W using the command
Switch(config)#power inline consumption default cmd
114
