c3640 Upgrade problem ***Help***
I have to upgrade some c3640's. The flash has the new and old image on the flash
old: c3640-is-mz.120-22.bin
new: c3640-is-mz.120-27.bin
The c3640 will not reload to new image at reload after issueing the command in global config
(config)#no boot system flash:c3640-is-mz.120-22.bin
(config)#boot system flash:c3640-is-mz.120-27.bin
#copy run sta
#reload
if i run the command
#sho boot
% Invalid input detected at '^' marker.
So any idea ?
Please note that i have followed the cisco software upgrade documentation............. and i have upgraded this same routers b/4
1 ACCEPTED SOLUTION
Silver
Re: c3640 Upgrade problem ***Help***
you are missing the colon between flash and c3600
needs to be
I ran in to this the other day I had to remove and renter it a few times in order for it to take .
Silver
can you paste in a sh flash
sho flash:
System flash directory:
File Length Name/status
1 5447876 c3640-is-mz.120-22.bin
2 5450324 c3640-is-mz.120-27.bin
[10898328 bytes used, 5878888 available, 16777216 total]
16384K bytes of processor board System flash (Read/Write)
under sho run i can see this:
boot system flash c3640-is-mz.120-27.bin
but when i do sho ver this is waht i see:
IOS (tm) 3600 Software (C3640-IS-M), Version 12.0(22), RELEASE SOFTWARE (fc1)
Copyright (c) 1986-2002 by cisco Systems, Inc.
Compiled Mon 01-Apr-02 21:11 by srani
Image text-base: 0x60008918, data-base: 0x609A8000
ROM: System Bootstrap, Version 11.1(20)AA2, EARLY DEPLOYMENT RELEASE SOFTWARE (f
c1)
sho flash:
c1)
Silver
needs to be
125
