08-29-2003 01:46 AM - edited 03-02-2019 09:58 AM
hello npc.
i have two c4000's that i would like to manage via cm/dfm. unfortunately the devices are discovered as "uncertified" in the dfm, and so discovery will not pass beyond them i guess.
their objectuid is .1.3.6.1.4.1.9.1.448 and the documentation at
says they are supported, while the status "uncertified" means , they're not listed in the config file "oid2types.conf".
is this maybe because of the relatively old os 12.1.(12c) EW ??
thanks in advance,
gerhard
08-29-2003 07:58 AM
.1.3.6.1.4.1.9.1.448= Cat4006. The device list that you're refering to above is for Campus Manager and not for DFM. Is this not showing in DFM. Correct?. What is the DFM/Campus Manager versions and corresponding IDU pacthes installed?
09-01-2003 12:59 AM
hello.
the device is showing as uncertified in dfm.
the versions are:
dfm 1.2
cm 3.3
idu-patch 1.2.5
can you help?
thanks,
gerhard
09-01-2003 01:31 PM
Is this running NativeIOS?. If so, then you'll have to wait for the next DFM IDU as it is not currently supported.
