07-25-2002 11:01 PM - edited 03-02-2019 12:11 AM
Can a Catalyst 6500 with Sup2 (MSFC2 & PFC2) using this Gigabit Ethernet Card (WS-X6816-GBIC) work without installing the SFM2 (WS-X6500-SFM2) ?
Can it work, however, cannot perform Distributed Switching only ? Pls advise ....
Rgds
07-26-2002 12:40 AM
HI,
See the datasheet for gigabit module on catalyst 6K :
http://www.cisco.com/warp/public/cc/pd/si/casi/ca6000/prodlit/c60ge_ds.htm
The module only support Switch fabric switching mode.
You can verify it with the software advisor, I suppose.
regards
07-26-2002 02:14 AM
The Datasheet mentioned about its capabilities to deliver switched fabric feature. However, if I don't install an SFM2, will the WS-X6816-GBIC work (even without the extra features) ?
p/s : I tried the configurator. Apparently, I cannot configure the WS-X6816-GBIC without adding the SFM2 in.
Rgds
07-26-2002 07:02 AM
You must install a Switch Fabric Module along with the WS-X6816-GBIC in the Catalyst 6500 Series switch.
http://www.cisco.com/univercd/cc/td/doc/product/lan/cat6000/6000hw/mod_inst/01overvw.htm#xtocid30
