C6K Port Index Assignment
Dear Network Professional Connection,
I would like to know the logic behind numbering physical and logical Ports e.g. AgPorts.
Example:
"CAT_OS> (enable) show spantree 1
Designated Root Port 2/1-4 (agPort 13/33) ..."
How will the numbering look like if I am using an 13 slot chassis?
Thanks in advance
  • Other Network Infrastructure Subjects
Re: C6K Port Index Assignment
This is and interesting question and to prove that it seems to be OS/IOS dependant i got the following info. These are two identical chassis on terms of SLOTS.
What i have found out is that it takes the AgPORT as a complete module and slot. Will be digging deeper.
From IOS Box:
Port-channel1:
Age of the Port-channel = 41h:50m:20s
Logical slot/port = 14/1 Number of ports = 2
GC = 0x00010001 HotStandBy port = null
Port state = Port-channel Ag-Inuse
Now from CatOS Box: ( I found a hidden Command playing with this)
I initially only had a single channel on ports 1/1-2
--- 13/1 ---
old_mem_cnt = 0; admin_group = 0; path_cost = 3; path_vlan_cost = 0
trunk_id = 768, time_stamp = 183231960, agifindex = 254
chnl_list = 1/1-2
agport_list = 1/1-2
bndlctrl: prtcnt = 2, num_map = c0, dist_req = 2, dist_port = 0
mod port bndl_port bndl_sel bndl_sel*
1 1 0 aa aa
1 2 1 55 55
0 0 0 0 0
0 0 0 0 0
0 0 0 0 0
0 0 0 0 0
0 0 0 0 0
0 0 0 0 0
--- 13/54 ---
old_mem_cnt = 0; admin_group = 0; path_cost = 7; path_vlan_cost = 0
trunk_id = 821, time_stamp = 198243982, agifindex = 256
chnl_list = 2/44-48
agport_list = 2/48
bndlctrl: prtcnt = 5, num_map = f8, dist_req = 2, dist_port = 0
2 44 0 0 0
2 45 1 0 0
2 46 2 0 0
2 47 3 0 0
2 48 4 ff ff
0 0 0 0 0
0 0 0 0 0
0 0 0 0 0
Thanks for the reply and effort,
this means that the Index creation depends on the OS and that one logical module is created to represent the channels? Cool idea!
I read that because of the introduction of the 6513 chassis the number of
FEC/GEC will be reduced form 128 down to 63 (64). Maybe from two logical
modules down to one? How many ports can a module logical/physical handle?
I assume up to 48 (maybe old samba limit?)...
The only open question would be which (by now 2) schemata is actually used...?
90
