C6K5-SUP720 running in Chassis with 1300Watt PS
I know that FAN2 and SUP720 are requiring a minimum
of one 2500Watt-PS.
Is it possible to use it in a Chassis with two 1300Watt-PS, if the redundancy-mode is disabled.
IOS-Switch#conf t
IOS-Switch#(config)power redundancy-mode combined
IOS-Switch#(config)
%C6KPWR-SP-4-PSCOMBINEDMODE: power supplies set to combined mode.
IOS-Switch#(config)end
IOS-Switch#
IOS-Switch#sh power
system power redundancy mode = combined
system power total = 2306.64 Watts (54.92 Amps @ 42V)
system power used = 712.32 Watts (16.96 Amps @ 42V)
system power available = 1594.32 Watts (37.96 Amps @ 42V)
Power-Capacity PS-Fan Output Oper
PS Type Watts A @42V Status Status State
1 WS-CAC-1300W 1153.32 27.46 OK OK on
2 WS-CAC-1300W 1153.32 27.46 OK OK on
Pwr-Requested Pwr-Allocated Admin Oper
Slot Card-Type Watts A @42V Watts A @42V State State
1 - - 142.38 3.39 - -
2 WS-X6K-SUP2-2GE 142.38 3.39 142.38 3.39 on on
3 WS-X6516-GBIC 142.80 3.40 142.80 3.40 on on
4 WS-X6248-RJ-45 112.98 2.69 112.98 2.69 on on
5 WS-SVC-FWM-1 171.78 4.09 171.78 4.09 on on
IOS-Switch#
I think it should be possible ??
Thanks in Advance
Hubert
1 REPLY
Re: C6K5-SUP720 running in Chassis with 1300Watt PS
It should work, but I would worry about how it'll perform when you start loading it with GBICs and clients. You'll probably run over the threshold where you can support the switch is one of those PS fails.
You might put yourself in a situation where you've created a two-points of failure system.
87
