08-26-2003 06:42 AM - edited 03-02-2019 09:53 AM
We have a Router 7204VXR, the fastethernet 0/1 lost the communication and blocking port, but the port continue up, the solution is reset port (shutdown, no shutdown), Somebody knows this problem?
08-26-2003 07:20 AM
blocking port ? Is the line protocol of the particular port down ? Please send us the output of the sh interface fastethernet0/1.
This might be due to some improper cabling or faulty switch ports.
08-26-2003 08:06 AM
the cabling is fine, and the switch port too.
this is a show interface:
FastEthernet0/1 is up, line protocol is up
Hardware is i82543 (Livengood), address is 0005.dcfa.0801 (bia 0005.dcfa.0801)
Description: omited
Internet address is omited
MTU 1500 bytes, BW 100000 Kbit, DLY 100 usec,
Keepalive set (10 sec)
Full-duplex, 100Mb/s, 100BaseTX/FX
Last input 02:57:18, output 00:00:08, output hang never
Last clearing of "show interface" counters 3d02h
Queueing strategy: fifo
Output queue 0/40, 0 drops; input queue 0/75, 71 drops
30 second input rate 0 bits/sec, 0 packets/sec
30 second output rate 0 bits/sec, 0 packets/sec
825863713 packets input, 3435169950 bytes
Received 0 broadcasts, 0 runts, 0 giants, 90 throttles
0 watchdog
609254483 packets output, 328093214 bytes, 0 underruns(0/0/0)
0 lost carrier, 0 no carrier
09-23-2003 10:57 PM
My name is Christophe, I've a same problem with a Cisco 7204VXR router, Sometimes the fast 0/1 port on I/O-2FE/E lost the communication, However this interface is UP,UP. The workarounds are ( shut/no shut ) or unplug /plug the ethernet cable.
I've looked your show interface fast 0/1, you have the same chipset ( Hardware is i82543 (Livengood) ) as mine.
The current runnning version is : c7200-is-mz.122-6.bin
Please find the show interface for this router :
This show has been taken during the problem.
Hardware is i82543 (Livengood), address is 0008.a4cd.2c06 (bia 0008.a4cd.2c06)
Description: Vers LAN
Internet address is 193.51.93.1/24
Last input 00:10:50, output 00:00:00, output hang never
Output queue 0/40, 100 drops; input queue 0/75, 29 drops
5 minute output rate 20000 bits/sec, 1 packets/sec
22562412 packets input, 3910674710 bytes
Received 0 broadcasts, 0 runts, 0 giants, 1 throttles
0 input errors, 38399 CRC, 0 frame, 0 overrun, 0 ignored
0 watchdog
20005052 packets output, 437914511 bytes, 0 underruns
0 output errors, 0 collisions, 6 interface resets
3 lost carrier, 0 no carrier
Do you have found any issue for this problem ( bugs SW, replacement HW, etc.... ) ?
Many thanks for your answer.
Best Regards,
09-24-2003 02:53 AM
Have you ckecked this?
"Cisco Security Advisory: Cisco IOS Interface Blocked by IPv4 Packets"
http://www.cisco.com/en/US/products/products_security_advisory09186a00801a34c2.shtml
09-24-2003 11:53 PM
I had this same issue with a 2620 2 weeks ago. TAC swore it was the nachi virus and not hardware. I humored TAC and setup the access-list to filter it. I setup debugs to try and capture what was casuing it. I/TAC didn't see any reason for the lost communication. I replaced the hardware and haven't experienced that problem again.
