C836 does not allow "reload at"
Hi one of our C836 does not allow a
C836#reload at 20:00
No bootable image in flash. Load an image into flash and try again; eg. using "copy tftp://<server>/<file> flash:"
Reload to ROM disallowed from a telnet line. Reload cancelled.
though a image is in flash:
Cisco836#dir
Directory of flash:/
1 -rw- 7223364 Feb 29 2004 21:27:05 +01:00
836-k9o3s8y6-mz.123-4.T3.bin
You can also see that the box booted from this image
------------------ show version ------------------
Cisco IOS Software, C836 Software (C836-K9O3S8Y6-M), Version 12.3(4)T3, RELEASE
SOFTWARE (fc3)
TAC Support: http://www.cisco.com/tac
Copyright (c) 1986-2004 by Cisco Systems, Inc.
Compiled Tue 10-Feb-04 04:51 by eaarmas
ROM: System Bootstrap, Version 12.2(11r)YV, RELEASE SOFTWARE (fc1)
<removed> uptime is 5 days, 14 hours, 33 minutes
System returned to ROM by reload at 18:06:44 GMT+1 Thu Mar 11 2004
System restarted at 18:08:12 GMT+1 Thu Mar 11 2004
System image file is "flash:c836-k9o3s8y6-mz.123-4.T3.bin"
A summary of U.S. laws governing Cisco cryptographic products may be found at:
export@cisco.com.
Cisco C836 (MPC857T) processor (revision 0x200) with 31130K/1638K bytes of memor
y.
Processor board ID AMB07270N6F (4181847588), with hardware revision 0000
CPU rev number 7
1 Ethernet interface
1 ISDN Basic Rate interface
1 ATM interface
128K bytes of NVRAM.
12288K bytes of processor board System flash (Read/Write)
2048K bytes of processor board Web flash (Read/Write)
Any idea about the reason ??
On 801 or 803-routers I had always seen a TinyRom-image in the flash, I do not so on the 836. does this box also need this TinyRom ??
Hubert
1 REPLY
Bronze
Re: C836 does not allow "reload at"
You may need to add a boot system statement in order to reload via telnet. The global config command is
boot system flash flash:c836-k9o3s8y6-mz.123-4.T3.bin
Make sure that's the only boot system statement.
Then write mem and try the "reload at" again.
209
