10-18-2002 06:53 AM - edited 03-02-2019 02:11 AM
Dear colleagues.
I have troubles with L3 switching on my C8510MSR box. CEF is running,
CEF and ARP tables builds correct, but packet switches via RSP process switching (IP input) with high performance degradation. There is no special configuration, it terminates 5 dot1Q trunks only. Any suggestion would be greatly appreciated. I have:
Zubr>sh ver
IOS (tm) Cat8510MSR WA5-5 Software (Cat8510M-WP-M), Version 12.1(12c)E1, EARLY DEPLOYMENT RELEASE SOFTWARE (fc1)
TAC Support: http://www.cisco.com/tac
Copyright (c) 1986-2002 by cisco Systems, Inc.
Compiled Wed 07-Aug-02 14:12 by eaarmas
Image text-base: 0x60010958, data-base: 0x60E50000
ROM: System Bootstrap, Version 11.2(1.4.WA3.0) [integ 1.4.WA3.0], RELEASE SOFTWARE
ROM: Cat8510MSR WA5-5 Software (Cat8510M-WP-M), Version 12.1(12c)E1, EARLY DEPLOYMENT RELEASE SOFTWARE (fc1)
Zubr uptime is 20 hours, 25 minutes
System restarted at 21:22:11 EEST Thu Oct 17 2002
System image file is "bootflash:cat8510m-wp-mz.121-12c.E1.bin"
cisco C8510msr (R4600) processor with 65536K bytes of memory.
R4700 CPU at 100Mhz, Implementation 33, Rev 1.0
Last reset from power-on
1 Ethernet/IEEE 802.3 interface(s)
8 FastEthernet/IEEE 802.3 interface(s)
5 ATM network interface(s)
123K bytes of non-volatile configuration memory.
16384K bytes of Flash internal SIMM (Sector size 256K).
Zubr>sh ip cef detail
IP CEF with switching (Table Version 3655), flags=0x0
524 routes, 0 reresolve, 0 unresolved (0 old, 0 new), peak 10
524 leaves, 81 nodes, 155672 bytes, 3662 inserts, 3138 invalidations
438 load sharing elements, 147168 bytes, 448 references
universal per-destination load sharing algorithm, id 5BE68BB5
4(0) CEF resets, 1721 revisions of existing leaves
Resolution Timer: Exponential (currently 1s, peak 2s)
0 in-place/0 aborted modifications
refcounts: 22396 leaf, 20992 node
Table epoch: 0 (524 entries at this epoch)
Adjacency Table has 268 adjacencies
2 incomplete adjacencies
0.0.0.0/0, version 97, epoch 0, per-destination sharing
0 packets, 0 bytes
tag information set
local tag: assigned-when-resolved-later
via 193.125.78.161, 0 dependencies, recursive
next hop 193.125.78.161, FastEthernet0/0/0.1 via 193.125.78.161/32
valid adjacency
Recursive load sharing using 193.125.78.161/32.
0.0.0.0/32, version 0, epoch 0, receive
10.0.0.0/8, version 3474, epoch 0, per-destination sharing
0 packets, 0 bytes
via 193.125.78.161, FastEthernet0/0/0.1, 0 dependencies
valid adjacency
0 packets, 0 bytes switched through the prefix
30 second output rate 0 Kbits/sec
10.0.0.0/16, version 147, epoch 0, per-destination sharing
0 packets, 0 bytes
valid adjacency
(0 packets, 0 bytes for all networks)
Zubr>sh int FastEthernet0/0/0 stats
FastEthernet0/0/0
Switching path Pkts In Chars In Pkts Out Chars Out
Processor 56508560 4064653781 32843851 1741191767
Route cache 0 0 0 0
Total 56508560 4064653781 32843851 1741191767
CPU utilization for five seconds: 99%/58%; one minute: 99%; five minutes: 99%
PID Runtime(ms) Invoked uSecs 5Sec 1Min 5Min TTY Process
1 0 1 0 0.00% 0.00% 0.00% 0 Chunk Manager
2 2476 14674 168 0.00% 0.00% 0.00% 0 Load Meter
3 17908 44998 397 0.00% 0.00% 0.00% 0 OSPF Hello
4 86156 10305 8360 0.89% 0.16% 0.11% 0 Check heaps
5 0 1 0 0.00% 0.00% 0.00% 0 Chunk Manager
52 39716528 9193723 4319 39.23% 38.29% 38.58% 0 IP Input
10-18-2002 06:59 AM
There is certain traffic that need to be process switched. What is configured on this FE
10-18-2002 09:04 AM
In my case, ALL traffic is process switched.
