Community Member
Cable and DSL VPN
We have 2 office networks connected via Cisco 827 DSL routers. We are using IPSEC and 3DES. The networks are connecting privately through the VPN. We are going to re-locate one of the offices to an area that does not have DSL available, but does have Cable Access. My Question… What is needed/recommended at the new location that will allow us to re-connect the office networks and still use the Cisco 827 DSL at the other location? We would like to continue the same type of connectivity via a VPN solution.
1 ACCEPTED SOLUTION
Re: Cable and DSL VPN
You can use Cisco's UBR 905 cable modem which supports IPSEC now as well. Here is the url for more information on that
http://www.cisco.com/warp/public/cc/pd/rt/900/prodlit/br905_qp.htm
Cisco's cable modems can be found at
http://www.cisco.com/univercd/cc/td/doc/product/cable/cab_modm/index.htm
Community Member
Thanks, this is what I needed to know.
Community Member
You may also wish to use the 806 broadband router which is a dual ethernet solution in case you decide to switch to dsl once it is available in that area. Or even the 3002 hardware client.
I suggest this because of lot more broadband providers won't support you if you don't have their cpe on the line.
Bob Watson
CCDA, CCNP
99
