cable monitor command in uBR7223
We use a uBR7223 with IOS v 12.1(11b) here. In order to test the new cable monitor command we connected a linux system running snort to the fastethernet port and issued the commands as per http://www.cisco.com/univercd/cc/td/doc/product/cable/cab_rout/cmtsfg/ufg_cmon.htm
But we are not seeing any packet being forwaded via the ethernet interface.
We were actually playing on a spare CMTS here, so the system was not connected live to the internet but we plugged 2 cable modem to the cable interface and tried to watch the traffic through them. We did one more dirty trick. We have only one ethernet interface, so that port was connected to the a machine running network registrar till the modem came online and once the modem came up we removed the cable and plugged it to the packet capture machine.
If you want I can send in the exact commands that we gave, but i guess they are fine. Does any one else got caught in the same problem? Did we mix up some where? What solutuion do you suggest to add another ethernet interface to the cmts?
We are using MC12C in case that helps.
raj
1 REPLY
Re: cable monitor command in uBR7223
Since there has been no response to your post, it appears to be either too complex or too rare an issue for other forum members to assist you. If you don't get a suitable response to your post, you may wish to review our resources at the online Technical Assistance Center (http://www.cisco.com/tac) or speak with a TAC engineer. You can open a TAC case online at http://www.cisco.com/tac/caseopen
If anyone else in the forum has some advice, please reply to this thread.
Thank you for posting.
131
