Callback 3745 E1 ISDN does not work, seems bug
The problem is that when we try to callback with an analog telehphone line it's working
when we try to callback trough an ISDN line it doesn't work:
It seemses to us that the called party number is not given back to the ISDN interface (see debug session).
*Mar 1 00:19:34.755: Called Party Number i = 0x81DEADBEEF, '`n', 0xDB, '`', Plan:ISDN, Type:Unknown
here respresented as '`n'
(DEAD BEEF? a progammers joke? ;-)
After intensive search on the Cisco site we cannot solve the problem,
Can you help us?
Thanks in advance
Leo Korbee
Slingeland Hospital
Doetinchem,
The Netherlands
We have a 3745 switch with the folowing configuration.
AS01#sh version
IOS (tm) 3700 Software (C3745-I-M), Version 12.2(8)T5, RELEASE SOFTWARE (fc1)
TAC Support: http://www.cisco.com/tac
Copyright (c) 1986-2002 by cisco Systems, Inc.
Compiled Thu 20-Jun-02 14:50 by ccai
Image text-base: 0x60008940, data-base: 0x60AEC000
ROM: System Bootstrap, Version 12.2(8r)T1, RELEASE SOFTWARE (fc1)
AS01 uptime is 1 minute
System returned to ROM by reload
System image file is "flash:C3745-I-MZ.122-8.T5.BIN"
cisco 3745 (R7000) processor (revision 53.51) with 131072K/12288K bytes of memory.
Processor board ID JMX0616K17P
R7000 CPU at 350Mhz, Implementation 39, Rev 3.3, 256KB L2, 2048KB L3 Cache
Channelized E1, Version 1.0.
MICA-6DM Firmware: CP ver 2730 - 5/23/2001, SP ver 2730 - 5/23/2001.
Bridging software.
X.25 software, Version 3.0.0.
Primary Rate ISDN software, Version 1.1.
2 FastEthernet/IEEE 802.3 interface(s)
31 Serial network interface(s)
12 terminal line(s)
1 Channelized E1/PRI port(s)
DRAM configuration is 64 bits wide with parity disabled.
151K bytes of non-volatile configuration memory.
31296K bytes of ATA System CompactFlash (Read/Write)
When we login With ISDN we get the following:
AS01#
*Mar 1 00:19:19.211: ISDN Se1/0:15: RX <- SETUP pd = 8 callref = 0x707E
*Mar 1 00:19:19.211: Bearer Capability i = 0x8890
*Mar 1 00:19:19.211: Channel ID i = 0xA18396
*Mar 1 00:19:19.211: Calling Party Number i = 0x2183, '314364851', Plan:ISDN, Type:National
*Mar 1 00:19:19.211: Called Party Number i = 0x80, Plan:Unknown, Type:Unknown
*Mar 1 00:19:19.243: %LINK-3-UPDOWN: Interface Serial1/0:21, changed state to up
*Mar 1 00:19:19.243: ISDN Se1/0:15: TX -> CALL_PROC pd = 8 callref = 0xF07E
*Mar 1 00:19:19.243: Channel ID i = 0xA98396
*Mar 1 00:19:19.243: ISDN Se1/0:15: TX -> CONNECT pd = 8 callref = 0xF07E
*Mar 1 00:19:19.243: Se1/0:21 PPP: Treating connection as a callin
*Mar 1 00:19:19.243: Se1/0:21 PPP: Phase is ESTABLISHING, Passive Open
*Mar 1 00:19:19.243: Se1/0:21 LCP: State is Listen
*Mar 1 00:19:19.303: ISDN Se1/0:15: RX <- CONNECT_ACK pd = 8 callref = 0x707E
*Mar 1 00:19:19.303: ISDN Se1/0:15: CALL_PROGRESS: CALL_CONNECTED call id 0x3, bchan 21, dsl 0
*Mar 1 00:19:19.567: Se1/0:21 LCP: I CONFREQ [Listen] id 0 len 30
*Mar 1 00:19:19.567: Se1/0:21 LCP: MagicNumber 0x78636A4C (0x050678636A4C)
*Mar 1 00:19:19.567: Se1/0:21 LCP: PFC (0x0702)
*Mar 1 00:19:19.567: Se1/0:21 LCP: ACFC (0x0802)
*Mar 1 00:19:19.567: Se1/0:21 LCP: Callback 6 (0x0D0306)
*Mar 1 00:19:19.567: Se1/0:21 LCP: MRRU 1614 (0x1104064E)
*Mar 1 00:19:19.567: Se1/0:21 LCP: EndpointDisc 3 0000.0000.0002 (0x130903000000000002)
*Mar 1 00:19:19.567: Se1/0:21 LCP: O CONFREQ [Listen] id 1 len 26
*Mar 1 00:19:19.567: Se1/0:21 LCP: AuthProto CHAP (0x0305C22305)
*Mar 1 00:19:19.567: Se1/0:21 LCP: MagicNumber 0x098E1364 (0x0506098E1364)
*Mar 1 00:19:19.567: Se1/0:21 LCP: MRRU 1524 (0x110405F4)
*Mar 1 00:19:19.567: Se1/0:21 LCP: EndpointDisc 1 AS01 (0x13070141533031)
*Mar 1 00:19:19.567: Se1/0:21 LCP: O CONFACK [Listen] id 0 len 30
*Mar 1 00:19:19.595: Se1/0:21 LCP: I CONFACK [ACKsent] id 1 len 26
*Mar 1 00:19:19.595: Se1/0:21 LCP: AuthProto CHAP (0x0305C22305)
*Mar 1 00:19:19.595: Se1/0:21 LCP: MagicNumber 0x098E1364 (0x0506098E1364)
*Mar 1 00:19:19.595: Se1/0:21 LCP: MRRU 1524 (0x110405F4)
*Mar 1 00:19:19.595: Se1/0:21 LCP: EndpointDisc 1 AS01 (0x13070141533031)
*Mar 1 00:19:19.595: Se1/0:21 LCP: State is Open
*Mar 1 00:19:19.595: Se1/0:21 PPP: Phase is AUTHENTICATING, by this end
*Mar 1 00:19:19.595: Se1/0:21 CHAP: O CHALLENGE id 1 len 25 from "AS01"
*Mar 1 00:19:19.603: Se1/0:21 LCP: I IDENTIFY [Open] id 1 len 18 magic 0x78636A4C MSRASV5.00
*Mar 1 00:19:19.607: Se1/0:21 LCP: I IDENTIFY [Open] id 2 len 22 magic 0x78636A4C MSRAS-1-TEST25
*Mar 1 00:19:19.623: Se1/0:21 CHAP: I RESPONSE id 1 len 29 from "dia10tst"
*Mar 1 00:19:19.695: Se1/0:21 DDR: Remote name for dia10tst
*Mar 1 00:19:19.695: Se1/0:21 DDR: Authenticated host dia10tst with no matching dialer map
*Mar 1 00:19:19.695: Se1/0:21 CHAP: O SUCCESS id 1 len 4
*Mar 1 00:19:19.695: Se1/0:21 MCB: User dia10tst Callback Number - Server 00314364872
*Mar 1 00:19:19.695: Serial1/0:21 PPP: O MCB Request(1) id 1 len 7
*Mar 1 00:19:19.695: Serial1/0:21 MCB: O 1 1 0 7 3 3 0
*Mar 1 00:19:19.695: Se1/0:21 MCB: O Request Id 1 Callback Type Server-Num delay 0
*Mar 1 00:19:19.695: Se1/0:21 PPP: Phase is CBCP
*Mar 1 00:19:19.723: Serial1/0:21 PPP: I MCB Response(2) id 1 len 7
*Mar 1 00:19:19.723: Serial1/0:21 MCB: I 2 1 0 7 3 3 A
*Mar 1 00:19:19.723: Se1/0:21 MCB: Received response
*Mar 1 00:19:19.723: Se1/0:21 MCB: Response CBK-Server-Num 3 3 10
*Mar 1 00:19:19.723: Serial1/0:21 PPP: O MCB Ack(3) id 2 len 7
*Mar 1 00:19:19.723: Serial1/0:21 MCB: O 3 2 0 7 3 3 A
*Mar 1 00:19:19.723: Se1/0:21 MCB: O Ack Id 2 Callback Type Server-Num delay 10
*Mar 1 00:19:19.723: Se1/0:21 MCB: Negotiated MCB with peer
*Mar 1 00:19:19.755: Se1/0:21 LCP: I TERMREQ [Open] id 3 len 16 (0x78636A4C003CCD7400000000)
*Mar 1 00:19:19.755: Se1/0:21 LCP: O TERMACK [Open] id 3 len 4
*Mar 1 00:19:19.755: Se1/0:21 MCB: Peer terminating the link
*Mar 1 00:19:19.755: Se1/0:21 MCB: Link terminated by peer, Callback Needed
`i^ at 00314364872 using ISDN DDRB: Initiate Callback for
*Mar 1 00:19:19.755: Se1/0:21 DDR: PPP callback Callback server starting to dia10tst 00314364872
*Mar 1 00:19:19.755: Se1/0:21 PPP: Phase is TERMINATING
*Mar 1 00:19:19.955: ISDN Se1/0:15: RX <- DISCONNECT pd = 8 callref = 0x707E
*Mar 1 00:19:19.955: Cause i = 0x8090 - Normal call clearing
*Mar 1 00:19:19.955: %ISDN-6-CONNECT: Interface Serial1/0:21 is now connected to 314364851 dia10tst
*Mar 1 00:19:19.991: %LINK-3-UPDOWN: Interface Serial1/0:21, changed state to down
*Mar 1 00:19:19.991: ISDN Se1/0:15: TX -> RELEASE pd = 8 callref = 0xF07E
*Mar 1 00:19:19.991: Se1/0:21 LCP: State is Closed
*Mar 1 00:19:19.991: Se1/0:21 PPP: Phase is DOWN
*Mar 1 00:19:19.991: Se1/0:21 DDR: disconnecting call
*Mar 1 00:19:20.047: ISDN Se1/0:15: RX <- RELEASE_COMP pd = 8 callref = 0x707E
*Mar 1 00:19:34.755: DDR: Callback timer expired
*Mar 1 00:19:34.755: Di10 DDR: beginning callback to dia10tst 00314364872
*Mar 1 00:19:34.755: Se1/0:15 DDR: rotor dialout [priority]
*Mar 1 00:19:34.755: Se1/0:15 DDR: Attempting to dial 00314364872
*Mar 1 00:19:34.755: DDR: Freeing callback to dia10tst 00314364872
*Mar 1 00:19:34.755: ISDN Se1/0:15: TX -> SETUP pd = 8 callref = 0x0003
*Mar 1 00:19:34.755: Bearer Capability i = 0x8890
*Mar 1 00:19:34.755: Channel ID i = 0xA9839F
*Mar 1 00:19:34.803: ISDN Se1/0:15: RX <- RELEASE_COMP pd = 8 callref = 0x8003
*Mar 1 00:19:34.803: Cause i = 0x81E470 - Invalid information element contents
*Mar 1 00:19:34.803: Serial1/0:15: wait for isdn carrier timeout, call id=0x8004
AS01#
1 ACCEPTED SOLUTION
Silver
Re: Callback 3745 E1 ISDN does not work, seems bug
This appears to be CSCdu50702 / CSCdw63293 "Callback is calling garbage" intergrated in 12.2(8.5)T....Please try the latest 12.2(15)T IOS image.
Thanks, Mak.
1 REPLY
Silver
Thanks, Mak.
121
