Callback between Cisco2621 and Cisco 760
I have got a problem to enable callback from a Cisco 760 to a Cisco 2621.
First, the Cisco 2621 calls the Cisco 760 and the connection is established.
Second, the call is cleared normally
Third, the 760 does not call back the 2621...
Do you have an example of a running Cisco 760 config with call back ?
Please see first the config of my 2621:
interface Dialer1
description connected to HRA BS
ip address 10.195.49.1 255.255.255.0
encapsulation ppp
no ip split-horizon
dialer pool 1
dialer string xxxxxx
dialer-group 1
no peer default ip address
no cdp enable
ppp callback request
ppp authentication chap pap callin
ppp multilink
interface BRI0/0
no ip address
encapsulation ppp
dialer pool-member 1
isdn switch-type basic-net3
The config of my Cisco760 is:
cd
set user XXXX
set ppp auth out chap
set ppp secret host
XXXX
XXXX
set ppp secret client
XXXX
XXXX
set ppp password host
XXXX
XXXX
set ppp password client
XXXX
XXXX
set ppp callback reply on
set compression stac
set bridging off
set ip address 10.195.49.30
set ip netmask 255.255.255.0
set ip routing on
set ip rip update demand
set number XXXX
set timeout 30
set ip route dest 10.49.64.0/0 gate 10.195.49.1
set active
set user XXXX
set ppp secret host
Thanks a lot for your help
  • Other Network Infrastructure Subjects
1 REPLY
Bronze
Re: Callback between Cisco2621 and Cisco 760
You can probably remove callback and check if the call goes through and see if authentication is successful, and then you can find where the problem is. This links has couple of configurations for 700 series routers : http://www.cisco.com/warp/public/129/20.html
76
