Webcast-Catalyst9k
Callback between PC WinNT4.0 and Cisco1721
I have a problem with my PC NT4.0 and a Cisco1721. I am triyng to callback, and the router not accept the authentication of the PC. The router accept the call, but don´t make the callback. "MCB: Callback not authoriced for this user".
The router configuration is:
hostname C_Verea
logging buffered 32000 debugging
logging console informational
enable password <deleted>
username Softgal01 password <deleted>
no ip name-server
isdn switch-type basic-net3
ip subnet-zero
no ip domain-lookup
ip routing
interface BRI 0
ip unnumbered FastEthernet 0
encapsulation ppp
dialer map ip 192.168.128.98 name Softgal01 class remaccess 981173772
dialer-group 1
no cdp enable
ppp callback accept
ppp authentication chap
no ppp multilink
map-class dialer remaccess
dialer callback-server username
interface FastEthernet 0
no shutdown
ip address 192.168.128.1 255.255.255.0
ip nat inside
keepalive 10
The active debugs are:
debug ppp nego
debug ppp cbcp
debug callback
The register of the debugs is:
*Mar 1 00:02:21: %LINK-3-UPDOWN: Interface BRI0:1, changed state to up
*Mar 1 00:02:21: BR0:1 PPP: Treating connection as a callin
*Mar 1 00:02:21: BR0:1 PPP: Phase is ESTABLISHING, Passive Open
*Mar 1 00:02:21: BR0:1 LCP: State is Listen
*Mar 1 00:02:21: BR0:1 LCP: I CONFREQ [Listen] id 1 len 40
*Mar 1 00:02:21: BR0:1 LCP: MagicNumber 0x000051F4 (0x0506000051F4)
*Mar 1 00:02:21: BR0:1 LCP: Callback 6 (0x0D0306)
*Mar 1 00:02:21: BR0:1 LCP: MRRU 1614 (0x1104064E)
*Mar 1 00:02:21: BR0:1 LCP: EndpointDisc 1 Local
*Mar 1 00:02:21: BR0:1 LCP: (0x131701CC4B0A20BFFA11D6BE1C000086)
*Mar 1 00:02:21: BR0:1 LCP: (0x5ED96900000000)
*Mar 1 00:02:21: BR0:1 LCP: O CONFREQ [Listen] id 1 len 15
*Mar 1 00:02:21: BR0:1 LCP: AuthProto CHAP (0x0305C22305)
*Mar 1 00:02:21: BR0:1 LCP: MagicNumber 0x0945BB10 (0x05060945BB10)
*Mar 1 00:02:21: BR0:1 LCP: O CONFREJ [Listen] id 1 len 8
*Mar 1 00:02:21: BR0:1 LCP: I CONFACK [REQsent] id 1 len 15
*Mar 1 00:02:21: BR0:1 LCP: I CONFREQ [ACKrcvd] id 2 len 36
*Mar 1 00:02:21: BR0:1 LCP: O CONFACK [ACKrcvd] id 2 len 36
*Mar 1 00:02:21: BR0:1 LCP: State is Open
*Mar 1 00:02:21: BR0:1 MCB: Initialize
*Mar 1 00:02:21: MCB: Flush
*Mar 1 00:02:21: BR0:1 PPP: Phase is AUTHENTICATING, by this end
*Mar 1 00:02:21: BR0:1 CHAP: O CHALLENGE id 1 len 28 from "C_Verea"
*Mar 1 00:02:21: BR0:1 LCP: I IDENTIFY [Open] id 3 len 18 magic 0x000051F4 MSRASV4.00
*Mar 1 00:02:21: BR0:1 LCP: I IDENTIFY [Open] id 4 len 23 magic 0x000051F4 MSRAS-1-LTE5250
*Mar 1 00:02:21: BR0:1 CHAP: I RESPONSE id 1 len 28 from "Softgal01"
*Mar 1 00:02:21: BR0:1 PPP: Phase is FORWARDING, Attempting Forward
*Mar 1 00:02:21: BR0:1 PPP: Phase is AUTHENTICATING, Unauthenticated User
*Mar 1 00:02:21: BR0:1 PPP: Phase is AUTHENTICATING, Authenticated User
*Mar 1 00:02:21: BR0:1 CHAP: O SUCCESS id 1 len 4
*Mar 1 00:02:21: BR0:1 MCB: Start
*Mar 1 00:02:21: BR0:1 MCB: Callback not authorized for this user Softgal01
*Mar 1 00:02:21: BR0:1 MCB: Newstate 0-INIT -> 2-WAIT_RESPONSE
*Mar 1 00:02:21: BRI0:1 PPP: O MCB Request(1) id 1 len 6
*Mar 1 00:02:21: BRI0:1 MCB: O 1 1 0 6 1 2
*Mar 1 00:02:21: BR0:1 MCB: O Request Id 1 Callback Type None
*Mar 1 00:02:21: BR0:1 PPP: Phase is CBCP
*Mar 1 00:02:21: BRI0:1 PPP: I MCB Response(2) id 1 len 6
*Mar 1 00:02:21: BRI0:1 MCB: I 2 1 0 6 1 2
*Mar 1 00:02:21: BR0:1 MCB: Received response
*Mar 1 00:02:21: BR0:1 MCB: Response CBK-None 1 2
*Mar 1 00:02:21: BRI0:1 PPP: O MCB Ack(3) id 2 len 6
*Mar 1 00:02:21: BRI0:1 MCB: O 3 2 0 6 1 2
*Mar 1 00:02:21: BR0:1 MCB: O Ack Id 2 Callback Type None
*Mar 1 00:02:21: BR0:1 MCB: No Callback negotiated; Exit
*Mar 1 00:02:21: BR0:1 MCB: Flush
*Mar 1 00:02:21: BR0:1 PPP: Phase is UP
*Mar 1 00:02:21: BR0:1 IPCP: O CONFREQ [Closed] id 1 len 10
*Mar 1 00:02:21: BR0:1 IPCP: Address 192.168.128.1 (0x0306C0A88001)
*Mar 1 00:02:21: BR0:1 CCP: I CONFREQ [Not negotiated] id 5 len 10
*Mar 1 00:02:21: BR0:1 CCP: MS-PPC supported bits 0x00000006 (0x120600000006)
*Mar 1 00:02:21: BR0:1 LCP: O PROTREJ [Open] id 2 len 16 protocol CCP (0x80FD0105000A120600000006)
*Mar 1 00:02:21: BR0:1 IPCP: I CONFREQ [REQsent] id 6 len 40
*Mar 1 00:02:21: BR0:1 IPCP: CompressType VJ 15 slots CompressSlotID (0x0206002D0F01)
*Mar 1 00:02:21: BR0:1 IPCP: Address 0.0.0.0 (0x030600000000)
*Mar 1 00:02:21: BR0:1 IPCP: PrimaryDNS 0.0.0.0 (0x810600000000)
*Mar 1 00:02:21: BR0:1 IPCP: PrimaryWINS 0.0.0.0 (0x820600000000)
*Mar 1 00:02:21: BR0:1 IPCP: SecondaryDNS 0.0.0.0 (0x830600000000)
*Mar 1 00:02:21: BR0:1 IPCP: SecondaryWINS 0.0.0.0 (0x840600000000)
*Mar 1 00:02:21: BR0:1 IPCP: O CONFREJ [REQsent] id 6 len 34
*Mar 1 00:02:21: BR0:1 IPCP: I CONFACK [REQsent] id 1 len 10
*Mar 1 00:02:21: BR0:1 IPCP: I CONFREQ [ACKrcvd] id 7 len 10
*Mar 1 00:02:21: BR0:1 IPCP: O CONFNAK [ACKrcvd] id 7 len 10
*Mar 1 00:02:21: BR0:1 IPCP: Address 192.168.128.98 (0x0306C0A88062)
*Mar 1 00:02:21: BR0:1 IPCP: I CONFREQ [ACKrcvd] id 8 len 10
*Mar 1 00:02:21: BR0:1 IPCP: O CONFACK [ACKrcvd] id 8 len 10
*Mar 1 00:02:21: BR0:1 IPCP: State is Open
*Mar 1 00:02:21: BR0 IPCP: Install route to 192.168.128.98
*Mar 1 00:02:21: BR0:1 IPCP: Add link info for cef entry 192.168.128.98
*Mar 1 00:02:22: %LINEPROTO-5-UPDOWN: Line protocol on Interface BRI0:1, changed state to up
*Mar 1 00:02:27: %ISDN-6-CONNECT: Interface BRI0:1 is now connected to 981173776 Softgal01
Thank you for your help. Best regards,
Carlos Mejuto
cmejuto@softgal.com
Re: Callback between PC WinNT4.0 and Cisco1721
Try using the dialer interface config on the callback server, just the way discussed at following url
http://www.cisco.com/warp/public/793/access_dial/isdn-ppp-callback.html
Thank you for you answer. Don´t work with dialer profile. I proved this method before.
Which is the problem? Why don`t work?
Carlos Mejuto
cmejuto@softgal.com
Try on interface BRI0
ppp authentication pap.
Best regards
I have experienced the same problem and finally got it working with interface BRI. Try setting up router with aaa and username .... dialerstring. Only difference with your situation is that the client PC i'm using has Windows 2000 installed.
The problem with this solution is that i only need one B-channel for callback, but now i have to use the BRI interface for this purpose.
Can't get callback working with dialerprofile, If anyone has a solution please let me know.
Best regards
Bronze
I'm not sure what version code you are at, but this could be CSCdw27654, which was a 12.2T bug fixed in 12.2(8.5)T and later code. The workaround is to do the following:
aaa new-model
and aaa authorization network local
If you are not running 12.2T code, then you might try as another workaround attempt the command "username Softgal01 callback-dialstring 981173772 password secret"; what is happening is that the IOS seems to think, right from the start, that this user is not authorized for callback.
92
