CallBack Problem with 2509
jpcastro
I've got the following problem with my callback configuration:
1) Dial-up with Windows 2000
2) The router answer the call and authenticate the user
3) The PC wait for the callback
4) The router dials to the PC
5) The PC answer the call
6) The PC can't authenticate user, the message "Verifying username and password" remains until error 619 comes. "The specific port...."
Here goes the config
version 12.0
service timestamps debug uptime
service timestamps log uptime
service password-encryption
hostname AS2509
aaa new-model
aaa authentication login default none
aaa authentication login use-local local
aaa authentication ppp default local
aaa authorization network default local
enable secret 5 $1$hLuh$A/KGbGt25g8I073GpT1tN/
enable password 7 030752180500
username znoopydog callback-dialstring 2390 password 7 07152F43411900011815
username cisco password 7 1511021F0725
ip subnet-zero
ip name-server 172.20.1.4
chat-script offhook "" "ATH1" OK
chat-script callback ABORT ERROR ABORT BUSY "" "ATZ" OK "ATDT \T" TIMEOUT 30 CONNECT \c
interface Ethernet0
ip address 172.80.10.11 255.255.0.0
no ip directed-broadcast
shutdown
no cdp enable
interface Serial0
no ip address
no ip mroute-cache
shutdown
no fair-queue
interface Serial1
no ip address
shutdown
no cdp enable
interface Group-Async1
ip unnumbered Ethernet0
encapsulation ppp
ip tcp header-compression passive
async mode interactive
peer default ip address pool setup_pool
no fair-queue
ppp max-bad-auth 10
ppp callback accept
ppp authentication chap
ppp multilink
group-range 1 8
ip local pool setup_pool 172.80.100.100 172.80.100.110
ip classless
ip route 0.0.0.0 0.0.0.0 172.80.0.1
access-list 105 permit ip any any
dialer-list 5 protocol ip list 105
line con 0
exec-timeout 0 0
transport input none
line 1 8
session-timeout 20
autoselect during-login
autoselect ppp
script modem-off-hook offhook
script callback callback
login authentication use-local
modem InOut
modem autoconfigure discovery
transport preferred none
transport input all
transport output none
callback forced-wait 10
stopbits 1
speed 38400
flowcontrol hardware
line aux 0
line vty 0 4
password 7 01100F175804
end
1d13h: %LINK-5-CHANGED: Interface Async5, changed state to reset
1d13h: %LINK-3-UPDOWN: Interface Async5, changed state to down
1d14h: %LINK-3-UPDOWN: Interface Async5, changed state to up
1d14h: As5 AAA/ACCT: Using PPP accounting list ""
1d14h: %LINK-5-CHANGED: Interface Async5, changed state to reset
1d14h: %LINK-3-UPDOWN: Interface Async5, changed state to down
1d14h: TTY5: timer_create_bg error
Any Ideas?
Juan Castro
5 Replies 5
tepatel
Here is the sample config for callback between router and windoes PC.
http://www.cisco.com/warp/public/793/access_dial/async_ppp.html
Now, if it deosn't work, we need to have a debug for following from the router to see where the issue can be.
debug ppp negotiation
debug modem
debug ppp cbcp
debug callback
debug aaa authorization
Debugs.
08:16:01: TTY4: autoconfigure probe started
08:16:09: TTY7: autoconfigure probe started
08:16:09: TTY6: autoconfigure probe started
08:16:09: TTY2: autoconfigure probe started
08:16:11: TTY3: autoconfigure probe started
08:16:17: TTY1: autoconfigure probe started
08:16:17: TTY8: autoconfigure probe started
08:16:27: TTY4: autoconfigure probe started
08:16:35: TTY7: autoconfigure probe started
08:16:35: TTY6: autoconfigure probe started
08:16:35: TTY2: autoconfigure probe started
08:16:37: TTY3: autoconfigure probe started
08:16:39: TTY5: DSR came up
08:16:39: tty5: Modem: IDLE->READY
08:16:39: TTY5: EXEC creation
08:16:39: TTY5: set timer type 10, 30 seconds
08:16:40: TTY5: Autoselect(2) sample 7E
08:16:40: TTY5: Autoselect(2) sample 7EFF
08:16:40: TTY5: Autoselect(2) sample 7EFF7D
08:16:40: TTY5: Autoselect(2) sample 7EFF7D23
08:16:40: TTY5 Autoselect cmd: ppp negotiate
08:16:40: TTY5: EXEC creation
08:16:40: TTY5: create timer type 1, 600 seconds
08:16:40: TTY5: destroy timer type 1 (OK)
08:16:40: TTY5: destroy timer type 0
08:16:40: TTY5: create timer type 2, 1200 seconds
08:16:42: TTY1: autoconfigure probe started
08:16:42: %LINK-3-UPDOWN: Interface Async5, changed state to up
08:16:42: As5 PPP: Treating connection as a dedicated line
08:16:42: As5 PPP: Phase is ESTABLISHING, Active Open
08:16:42: As5 LCP: O CONFREQ [Closed] id 178 len 25
08:16:42: As5 LCP: ACCM 0x000A0000 (0x0206000A0000)
08:16:42: As5 LCP: AuthProto CHAP (0x0305C22305)
08:16:42: As5 LCP: MagicNumber 0x521B4146 (0x0506521B4146)
08:16:42: As5 LCP: PFC (0x0702)
08:16:42: As5 LCP: ACFC (0x0802)
08:16:42: As5 LCP: I CONFACK [REQsent] id 178 len 25
08:16:43: TTY8: autoconfigure probe started
08:16:43: As5 LCP: I CONFREQ [ACKrcvd] id 2 len 50
08:16:43: As5 LCP: ACCM 0x00000000 (0x020600000000)
08:16:43: As5 LCP: MagicNumber 0x726F60A6 (0x0506726F60A6)
08:16:43: As5 LCP: PFC (0x0702)
08:16:43: As5 LCP: ACFC (0x0802)
08:16:43: As5 LCP: Callback 6 (0x0D0306)
08:16:43: As5 LCP: MRRU 1614 (0x1104064E)
08:16:43: As5 LCP: EndpointDisc 1 Local
08:16:43: As5 LCP: (0x1317015DF477464F9E43ADB6C56CCEA3)
08:16:43: As5 LCP: (0xE83D4900000000)
08:16:43: As5 LCP: O CONFREJ [ACKrcvd] id 2 len 31
08:16:43: As5 LCP: I CONFREQ [ACKrcvd] id 3 len 23
08:16:43: As5 LCP: O CONFACK [ACKrcvd] id 3 len 23
08:16:43: As5 LCP: State is Open
08:16:43: As5 PPP: Phase is AUTHENTICATING, by this end
08:16:43: As5 CHAP: O CHALLENGE id 35 len 27 from "AS2509"
08:16:43: As5 LCP: I IDENTIFY [Open] id 4 len 18 magic 0x726F60A6 MSRASV5.00
08:16:43: As5 LCP: I IDENTIFY [Open] id 5 len 24 magic 0x726F60A6 MSRAS-1-THINKPAD
08:16:43: As5 CHAP: I RESPONSE id 35 len 30 from "znoopydog"
08:16:43: As5 CHAP: O SUCCESS id 35 len 4
08:16:43: As5 MCB: User znoopydog Callback Number - Server 2390
08:16:44: Async5 PPP: O MCB Request(1) id 56 len 7
08:16:44: Async5 MCB: O 1 38 0 7 3 3 0
08:16:44: As5 MCB: O Request Id 56 Callback Type Server-Num delay 0
08:16:44: As5 PPP: Phase is CBCP
08:16:44: Async5 PPP: I MCB Response(2) id 56 len 7
08:16:44: Async5 MCB: I 2 38 0 7 3 3 C
08:16:44: As5 MCB: Received response
08:16:44: As5 MCB: Response CBK-Server-Num 3 3 12
08:16:44: Async5 PPP: O MCB Ack(3) id 57 len 7
08:16:44: Async5 MCB: O 3 39 0 7 3 3 C
08:16:44: As5 MCB: O Ack Id 57 Callback Type Server-Num delay 12
08:16:44: As5 MCB: Negotiated MCB with peer
08:16:44: As5 LCP: I TERMREQ [Open] id 6 len 16 (0x726F60A6003CCD7400000000)
08:16:44: As5 LCP: O TERMACK [Open] id 6 len 4
08:16:44: As5 MCB: Peer terminating the link
08:16:44: As5 PPP: Phase is TERMINATING
08:16:44: As5 MCB: Link terminated by peer, Callback Needed
08:16:44: As5 MCB: Initiate Callback for znoopydog at 2390 using Async
08:16:44: As5 MCB: Async-callback in progress
08:16:44: As5 AAA/ACCT: Using PPP accounting list ""
08:16:46: As5 LCP: TIMEout: State TERMsent
08:16:46: As5 LCP: State is Closed
08:16:46: As5 PPP: Phase is DOWN
08:16:46: TTY5: Async Int reset: Dropping DTR
08:16:46: As5 PPP: Phase is ESTABLISHING, Passive Open
08:16:46: As5 LCP: State is Listen
08:16:48: %LINK-5-CHANGED: Interface Async5, changed state to reset
08:16:48: As5 LCP: State is Closed
08:16:48: As5 PPP: Phase is DOWN
08:16:48: As5 IPCP: Remove route to 172.80.100.100
08:16:52: TTY4: autoconfigure probe started
08:16:53: %LINK-3-UPDOWN: Interface Async5, changed state to down
08:16:53: As5 LCP: State is Closed
08:16:53: As5 PPP: Phase is DOWN
08:17:00: TTY2: autoconfigure probe started
08:17:00: TTY6: autoconfigure probe started
08:17:00: TTY7: autoconfigure probe started
08:17:01: CHAT5: Asserting DTR
08:17:02: TTY3: autoconfigure probe started
08:17:07: TTY1: autoconfigure probe started
08:17:08: TTY8: autoconfigure probe started
08:17:17: TTY4: autoconfigure probe started
08:17:23: TTY5: destroy timer type 1
08:17:23: TTY5: destroy timer type 0
08:17:23: TTY5: create timer type 2, 1200 seconds
08:17:23: TTY5: timer_create_bg error
08:17:25: %LINK-3-UPDOWN: Interface Async5, changed state to up
08:17:25: As5 PPP: Treating connection as a dedicated line
08:17:25: As5 PPP: Phase is ESTABLISHING, Active Open
08:17:25: As5 LCP: O CONFREQ [Closed] id 179 len 25
08:17:25: As5 LCP: ACCM 0x000A0000 (0x0206000A0000)
08:17:25: As5 LCP: AuthProto CHAP (0x0305C22305)
08:17:25: As5 LCP: MagicNumber 0x521BEA01 (0x0506521BEA01)
08:17:25: As5 LCP: PFC (0x0702)
08:17:25: As5 LCP: ACFC (0x0802)
08:17:26: TTY2: autoconfigure probe started
08:17:26: TTY7: autoconfigure probe started
08:17:26: TTY6: autoconfigure probe started
08:17:27: As5 LCP: TIMEout: State REQsent
08:17:27: As5 LCP: O CONFREQ [REQsent] id 180 len 25
08:17:27: As5 LCP: ACCM 0x000A0000 (0x0206000A0000)
08:17:27: As5 LCP: AuthProto CHAP (0x0305C22305)
08:17:27: As5 LCP: MagicNumber 0x521BEA01 (0x0506521BEA01)
08:17:27: As5 LCP: PFC (0x0702)
08:17:27: As5 LCP: ACFC (0x0802)
08:17:28: TTY3: autoconfigure probe started
08:17:29: As5 LCP: TIMEout: State REQsent
08:17:29: As5 LCP: O CONFREQ [REQsent] id 181 len 25
08:17:29: As5 LCP: ACCM 0x000A0000 (0x0206000A0000)
08:17:29: As5 LCP: AuthProto CHAP (0x0305C22305)
08:17:29: As5 LCP: MagicNumber 0x521BEA01 (0x0506521BEA01)
08:17:29: As5 LCP: PFC (0x0702)
08:17:29: As5 LCP: ACFC (0x0802)
08:17:31: As5 LCP: TIMEout: State REQsent
08:17:31: As5 LCP: O CONFREQ [REQsent] id 182 len 25
08:17:31: As5 LCP: ACCM 0x000A0000 (0x0206000A0000)
08:17:31: As5 LCP: AuthProto CHAP (0x0305C22305)
08:17:31: As5 LCP: MagicNumber 0x521BEA01 (0x0506521BEA01)
08:17:31: As5 LCP: PFC (0x0702)
08:17:31: As5 LCP: ACFC (0x0802)
08:17:32: TTY1: autoconfigure probe started
08:17:33: TTY8: autoconfigure probe started
08:17:33: As5 LCP: TIMEout: State REQsent
08:17:33: As5 LCP: O CONFREQ [REQsent] id 183 len 25
08:17:33: As5 LCP: ACCM 0x000A0000 (0x0206000A0000)
08:17:33: As5 LCP: AuthProto CHAP (0x0305C22305)
08:17:33: As5 LCP: MagicNumber 0x521BEA01 (0x0506521BEA01)
08:17:33: As5 LCP: PFC (0x0702)
08:17:33: As5 LCP: ACFC (0x0802)
08:17:35: As5 LCP: TIMEout: State REQsent
08:17:35: As5 LCP: O CONFREQ [REQsent] id 184 len 25
08:17:35: As5 LCP: ACCM 0x000A0000 (0x0206000A0000)
08:17:35: As5 LCP: AuthProto CHAP (0x0305C22305)
08:17:35: As5 LCP: MagicNumber 0x521BEA01 (0x0506521BEA01)
08:17:35: As5 LCP: PFC (0x0702)
08:17:35: As5 LCP: ACFC (0x0802)
08:17:37: As5 LCP: TIMEout: State REQsent
08:17:37: As5 LCP: O CONFREQ [REQsent] id 185 len 25
08:17:37: As5 LCP: ACCM 0x000A0000 (0x0206000A0000)
08:17:37: As5 LCP: AuthProto CHAP (0x0305C22305)
08:17:37: As5 LCP: MagicNumber 0x521BEA01 (0x0506521BEA01)
08:17:37: As5 LCP: PFC (0x0702)
08:17:37: As5 LCP: ACFC (0x0802)
08:17:39: As5 LCP: TIMEout: State REQsent
08:17:39: As5 LCP: O CONFREQ [REQsent] id 186 len 25
08:17:39: As5 LCP: ACCM 0x000A0000 (0x0206000A0000)
08:17:39: As5 LCP: AuthProto CHAP (0x0305C22305)
08:17:39: As5 LCP: MagicNumber 0x521BEA01 (0x0506521BEA01)
08:17:39: As5 LCP: PFC (0x0702)
08:17:40: As5 LCP: ACFC (0x0802)
08:17:42: As5 LCP: TIMEout: State REQsent
08:17:42: As5 LCP: O CONFREQ [REQsent] id 187 len 25
08:17:42: As5 LCP: ACCM 0x000A0000 (0x0206000A0000)
08:17:42: As5 LCP: AuthProto CHAP (0x0305C22305)
08:17:42: As5 LCP: MagicNumber 0x521BEA01 (0x0506521BEA01)
08:17:42: As5 LCP: PFC (0x0702)
08:17:42: As5 LCP: ACFC (0x0802)
08:17:43: TTY4: autoconfigure probe started
08:17:44: As5 LCP: TIMEout: State REQsent
08:17:44: As5 LCP: O CONFREQ [REQsent] id 188 len 25
08:17:44: As5 LCP: ACCM 0x000A0000 (0x0206000A0000)
08:17:44: As5 LCP: AuthProto CHAP (0x0305C22305)
08:17:44: As5 LCP: MagicNumber 0x521BEA01 (0x0506521BEA01)
08:17:44: As5 LCP: PFC (0x0702)
08:17:44: As5 LCP: ACFC (0x0802)
08:17:46: As5 LCP: TIMEout: State REQsent
08:17:46: As5 LCP: O CONFREQ [REQsent] id 189 len 25
08:17:46: As5 LCP: ACCM 0x000A0000 (0x0206000A0000)
08:17:46: As5 LCP: AuthProto CHAP (0x0305C22305)
08:17:46: As5 LCP: MagicNumber 0x521BEA01 (0x0506521BEA01)
08:17:46: As5 LCP: PFC (0x0702)
08:17:46: As5 LCP: ACFC (0x0802)
08:17:48: As5 LCP: TIMEout: State REQsent
08:17:48: TTY5: Async Int reset: Dropping DTR
08:17:48: As5 LCP: State is Listen
08:17:49: TTY5: DSR was dropped
08:17:49: tty5: Modem: READY->HANGUP
08:17:50: %LINK-5-CHANGED: Interface Async5, changed state to reset
08:17:50: As5 LCP: State is Closed
08:17:50: As5 PPP: Phase is DOWN
08:17:50: TTY5: dropping DTR, hanging up
08:17:50: tty5: Modem: HANGUP->IDLE
08:17:51: TTY5: cleanup pending. Delaying DTR
08:17:52: TTY5: cleanup pending. Delaying DTR
08:17:52: TTY2: autoconfigure probe started
08:17:52: TTY7: autoconfigure probe started
08:17:52: TTY6: autoconfigure probe started
08:17:53: TTY5: destroy timer type 0
08:17:53: TTY5: destroy timer type 1
08:17:53: TTY5: destroy timer type 3
08:17:53: TTY5: destroy timer type 4
08:17:53: TTY5: destroy timer type 2 (OK)
08:17:53: Async5: allowing modem_process to continue hangup
08:17:54: TTY5: restoring DTR
08:17:54: TTY5: autoconfigure probe started
08:17:54: TTY3: autoconfigure probe started
08:17:55: %LINK-3-UPDOWN: Interface Async5, changed state to down
08:17:55: As5 LCP: State is Closed
08:17:55: As5 PPP: Phase is DOWN
08:17:58: TTY1: autoconfigure probe started
08:17:59: TTY8: autoconfigure probe started
AS2509#
08:18:17: TTY2: autoconfigure probe started
08:18:17: TTY7: autoconfigure probe started
08:18:17: TTY6: autoconfigure probe started
08:18:20: TTY3: autoconfigure probe started
08:18:24: TTY1: autoconfigure probe started
08:18:25: TTY8: autoconfigure probe started
08:18:33: TTY4: autoconfigure probe started
08:18:43: TTY2: autoconfigure probe started
08:18:43: TTY7: autoconfigure probe started
08:18:43: TTY6: autoconfigure probe started
08:18:46: TTY3: autoconfigure probe started
08:18:50: TTY1: autoconfigure probe started
08:18:51: TTY8: autoconfigure probe started
08:18:59: TTY4: autoconfigure probe started
08:19:09: TTY2: autoconfigure probe started
08:19:09: TTY7: autoconfigure probe started
08:19:09: TTY6: autoconfigure probe started
08:19:12: TTY5: DSR came up
08:19:12: tty5: Modem: IDLE->READY
08:19:12: TTY3: autoconfigure probe started
08:19:12: TTY5: EXEC creation
08:19:12: TTY5: set timer type 10, 30 seconds
08:19:14: TTY5: Autoselect(2) sample 7E
08:19:14: TTY5: Autoselect(2) sample 7EFF
08:19:14: TTY5: Autoselect(2) sample 7EFF7D
08:19:14: TTY5: Autoselect(2) sample 7EFF7D23
08:19:14: TTY5 Autoselect cmd: ppp negotiate
08:19:14: TTY5: EXEC creation
08:19:14: TTY5: create timer type 1, 600 seconds
08:19:14: TTY5: destroy timer type 1 (OK)
08:19:14: TTY5: destroy timer type 0
08:19:14: TTY5: create timer type 2, 1200 seconds
08:19:16: %LINK-3-UPDOWN: Interface Async5, changed state to up
08:19:16: As5 PPP: Treating connection as a dedicated line
08:19:16: As5 PPP: Phase is ESTABLISHING, Active Open
08:19:16: As5 LCP: O CONFREQ [Closed] id 190 len 25
08:19:16: As5 LCP: ACCM 0x000A0000 (0x0206000A0000)
08:19:16: As5 LCP: AuthProto CHAP (0x0305C22305)
08:19:16: As5 LCP: MagicNumber 0x521D996F (0x0506521D996F)
08:19:16: As5 LCP: PFC (0x0702)
08:19:16: As5 LCP: ACFC (0x0802)
08:19:16: TTY1: autoconfigure probe started
08:19:16: TTY8: autoconfigure probe started
08:19:16: As5 LCP: I CONFACK [REQsent] id 190 len 25
08:19:17: As5 LCP: I CONFREQ [ACKrcvd] id 2 len 50
08:19:17: As5 LCP: ACCM 0x00000000 (0x020600000000)
08:19:17: As5 LCP: MagicNumber 0x1A0C6630 (0x05061A0C6630)
08:19:17: As5 LCP: PFC (0x0702)
08:19:17: As5 LCP: ACFC (0x0802)
08:19:17: As5 LCP: Callback 6 (0x0D0306)
08:19:17: As5 LCP: MRRU 1614 (0x1104064E)
08:19:17: As5 LCP: EndpointDisc 1 Local
08:19:17: As5 LCP: (0x1317015DF477464F9E43ADB6C56CCEA3)
08:19:17: As5 LCP: (0xE83D4900000000)
08:19:17: As5 LCP: O CONFREJ [ACKrcvd] id 2 len 31
08:19:17: As5 LCP: I CONFREQ [ACKrcvd] id 3 len 23
08:19:17: As5 LCP: O CONFACK [ACKrcvd] id 3 len 23
08:19:17: As5 LCP: State is Open
08:19:17: As5 PPP: Phase is AUTHENTICATING, by this end
08:19:17: As5 CHAP: O CHALLENGE id 36 len 27 from "AS2509"
08:19:17: As5 LCP: I IDENTIFY [Open] id 4 len 18 magic 0x1A0C6630 MSRASV5.00
08:19:17: As5 LCP: I IDENTIFY [Open] id 5 len 24 magic 0x1A0C6630 MSRAS-1-THINKPAD
08:19:17: As5 CHAP: I RESPONSE id 36 len 30 from "znoopydog"
08:19:17: As5 CHAP: O SUCCESS id 36 len 4
08:19:17: As5 MCB: User znoopydog Callback Number - Server 2390
08:19:17: Async5 PPP: O MCB Request(1) id 58 len 7
08:19:17: Async5 MCB: O 1 3A 0 7 3 3 0
08:19:17: As5 MCB: O Request Id 58 Callback Type Server-Num delay 0
08:19:17: As5 PPP: Phase is CBCP
08:19:17: Async5 PPP: I MCB Response(2) id 58 len 7
08:19:17: Async5 MCB: I 2 3A 0 7 3 3 C
08:19:17: As5 MCB: Received response
08:19:17: As5 MCB: Response CBK-Server-Num 3 3 12
08:19:17: Async5 PPP: O MCB Ack(3) id 59 len 7
08:19:17: Async5 MCB: O 3 3B 0 7 3 3 C
08:19:17: As5 MCB: O Ack Id 59 Callback Type Server-Num delay 12
08:19:17: As5 MCB: Negotiated MCB with peer
08:19:17: As5 LCP: I TERMREQ [Open] id 6 len 16 (0x1A0C6630003CCD7400000000)
08:19:17: As5 LCP: O TERMACK [Open] id 6 len 4
08:19:17: As5 MCB: Peer terminating the link
08:19:17: As5 PPP: Phase is TERMINATING
08:19:17: As5 MCB: Link terminated by peer, Callback Needed
08:19:17: As5 MCB: Initiate Callback for znoopydog at 2390 using Async
08:19:17: As5 MCB: Async-callback in progress
08:19:17: As5 AAA/ACCT: Using PPP accounting list ""
08:19:19: As5 LCP: TIMEout: State TERMsent
08:19:19: As5 LCP: State is Closed
08:19:19: As5 PPP: Phase is DOWN
08:19:19: TTY5: Async Int reset: Dropping DTR
08:19:19: As5 PPP: Phase is ESTABLISHING, Passive Open
08:19:19: As5 LCP: State is Listen
08:19:21: %LINK-5-CHANGED: Interface Async5, changed state to reset
08:19:21: As5 LCP: State is Closed
08:19:21: As5 PPP: Phase is DOWN
08:19:21: As5 IPCP: Remove route to 172.80.100.101
08:19:24: TTY4: autoconfigure probe started
08:19:26: %LINK-3-UPDOWN: Interface Async5, changed state to down
08:19:26: As5 LCP: State is Closed
08:19:26: As5 PPP: Phase is DOWN
08:19:34: TTY2: autoconfigure probe started
08:19:34: TTY7: autoconfigure probe started
08:19:34: TTY6: autoconfigure probe started
08:19:34: CHAT5: Asserting DTR
08:19:35: CHAT5: Asserting DTR
08:19:37: TTY3: autoconfigure probe started
08:19:41: TTY1: autoconfigure probe started
08:19:41: TTY8: autoconfigure probe started
08:19:49: TTY4: autoconfigure probe started
08:19:57: TTY5: destroy timer type 1
08:19:57: TTY5: destroy timer type 0
08:19:57: TTY5: create timer type 2, 1200 seconds
08:19:57: TTY5: timer_create_bg error
08:19:59: %LINK-3-UPDOWN: Interface Async5, changed state to up
08:19:59: As5 PPP: Treating connection as a dedicated line
08:19:59: As5 PPP: Phase is ESTABLISHING, Active Open
08:19:59: As5 LCP: O CONFREQ [Closed] id 191 len 25
08:19:59: As5 LCP: ACCM 0x000A0000 (0x0206000A0000)
08:19:59: As5 LCP: AuthProto CHAP (0x0305C22305)
08:19:59: As5 LCP: MagicNumber 0x521E421A (0x0506521E421A)
08:19:59: As5 LCP: PFC (0x0702)
08:19:59: As5 LCP: ACFC (0x0802)
08:19:59: TTY7: autoconfigure probe started
08:19:59: TTY2: autoconfigure probe started
08:19:59: TTY6: autoconfigure probe started
08:20:01: As5 LCP: TIMEout: State REQsent
08:20:01: As5 LCP: O CONFREQ [REQsent] id 192 len 25
08:20:01: As5 LCP: ACCM 0x000A0000 (0x0206000A0000)
08:20:01: As5 LCP: AuthProto CHAP (0x0305C22305)
08:20:01: As5 LCP: MagicNumber 0x521E421A (0x0506521E421A)
08:20:01: As5 LCP: PFC (0x0702)
08:20:01: As5 LCP: ACFC (0x0802)
08:20:02: TTY3: autoconfigure probe started
08:20:03: As5 LCP: TIMEout: State REQsent
08:20:03: As5 LCP: O CONFREQ [REQsent] id 193 len 25
08:20:03: As5 LCP: ACCM 0x000A0000 (0x0206000A0000)
08:20:03: As5 LCP: AuthProto CHAP (0x0305C22305)
08:20:03: As5 LCP: MagicNumber 0x521E421A (0x0506521E421A)
08:20:03: As5 LCP: PFC (0x0702)
08:20:03: As5 LCP: ACFC (0x0802)
08:20:05: As5 LCP: TIMEout: State REQsent
08:20:05: As5 LCP: O CONFREQ [REQsent] id 194 len 25
08:20:05: As5 LCP: ACCM 0x000A0000 (0x0206000A0000)
08:20:05: As5 LCP: AuthProto CHAP (0x0305C22305)
08:20:05: As5 LCP: MagicNumber 0x521E421A (0x0506521E421A)
08:20:05: As5 LCP: PFC (0x0702)
08:20:05: As5 LCP: ACFC (0x0802)
08:20:06: TTY1: autoconfigure probe started
08:20:06: TTY8: autoconfigure probe started
08:20:07: As5 LCP: TIMEout: State REQsent
08:20:07: As5 LCP: O CONFREQ [REQsent] id 195 len 25
08:20:07: As5 LCP: ACCM 0x000A0000 (0x0206000A0000)
08:20:07: As5 LCP: AuthProto CHAP (0x0305C22305)
08:20:07: As5 LCP: MagicNumber 0x521E421A (0x0506521E421A)
08:20:07: As5 LCP: PFC (0x0702)
08:20:07: As5 LCP: ACFC (0x0802)
08:20:09: As5 LCP: TIMEout: State REQsent
08:20:09: As5 LCP: O CONFREQ [REQsent] id 196 len 25
08:20:09: As5 LCP: ACCM 0x000A0000 (0x0206000A0000)
08:20:09: As5 LCP: AuthProto CHAP (0x0305C22305)
08:20:09: As5 LCP: MagicNumber 0x521E421A (0x0506521E421A)
08:20:09: As5 LCP: PFC (0x0702)
08:20:09: As5 LCP: ACFC (0x0802)
08:20:11: As5 LCP: TIMEout: State REQsent
08:20:11: As5 LCP: O CONFREQ [REQsent] id 197 len 25
08:20:11: As5 LCP: ACCM 0x000A0000 (0x0206000A0000)
08:20:11: As5 LCP: AuthProto CHAP (0x0305C22305)
08:20:11: As5 LCP: MagicNumber 0x521E421A (0x0506521E421A)
08:20:11: As5 LCP: PFC (0x0702)
08:20:11: As5 LCP: ACFC (0x0802)
08:20:13: As5 LCP: TIMEout: State REQsent
08:20:13: As5 LCP: O CONFREQ [REQsent] id 198 len 25
08:20:13: As5 LCP: ACCM 0x000A0000 (0x0206000A0000)
08:20:13: As5 LCP: AuthProto CHAP (0x0305C22305)
08:20:13: As5 LCP: MagicNumber 0x521E421A (0x0506521E421A)
08:20:13: As5 LCP: PFC (0x0702)
08:20:13: As5 LCP: ACFC (0x0802)
08:20:14: TTY4: autoconfigure probe started
08:20:15: As5 LCP: TIMEout: State REQsent
08:20:15: As5 LCP: O CONFREQ [REQsent] id 199 len 25
08:20:15: As5 LCP: ACCM 0x000A0000 (0x0206000A0000)
08:20:15: As5 LCP: AuthProto CHAP (0x0305C22305)
08:20:15: As5 LCP: MagicNumber 0x521E421A (0x0506521E421A)
08:20:15: As5 LCP: PFC (0x0702)
08:20:15: As5 LCP: ACFC (0x0802)
08:20:17: As5 LCP: TIMEout: State REQsent
08:20:17: As5 LCP: O CONFREQ [REQsent] id 200 len 25
08:20:17: As5 LCP: ACCM 0x000A0000 (0x0206000A0000)
08:20:17: As5 LCP: AuthProto CHAP (0x0305C22305)
08:20:17: As5 LCP: MagicNumber 0x521E421A (0x0506521E421A)
08:20:17: As5 LCP: PFC (0x0702)
08:20:17: As5 LCP: ACFC (0x0802)
08:20:19: As5 LCP: TIMEout: State REQsent
08:20:19: As5 LCP: O CONFREQ [REQsent] id 201 len 25
08:20:19: As5 LCP: ACCM 0x000A0000 (0x0206000A0000)
08:20:19: As5 LCP: AuthProto CHAP (0x0305C22305)
08:20:19: As5 LCP: MagicNumber 0x521E421A (0x0506521E421A)
08:20:19: As5 LCP: PFC (0x0702)
08:20:19: As5 LCP: ACFC (0x0802)
08:20:21: As5 LCP: TIMEout: State REQsent
08:20:21: TTY5: Async Int reset: Dropping DTR
08:20:21: As5 LCP: State is Listen
08:20:22: TTY5: DSR was dropped
08:20:22: tty5: Modem: READY->HANGUP
08:20:23: TTY5: dropping DTR, hanging up
08:20:23: tty5: Modem: HANGUP->IDLE
08:20:23: %LINK-5-CHANGED: Interface Async5, changed state to reset
08:20:23: As5 LCP: State is Closed
08:20:23: As5 PPP: Phase is DOWN
08:20:24: TTY5: cleanup pending. Delaying DTR
08:20:25: TTY5: cleanup pending. Delaying DTR
08:20:25: TTY2: autoconfigure probe started
08:20:25: TTY7: autoconfigure probe started
08:20:25: TTY6: autoconfigure probe started
08:20:26: TTY5: cleanup pending. Delaying DTR
08:20:26: TTY5: destroy timer type 0
08:20:26: TTY5: destroy timer type 1
08:20:26: TTY5: destroy timer type 3
08:20:26: TTY5: destroy timer type 4
08:20:26: TTY5: destroy timer type 2 (OK)
08:20:26: Async5: allowing modem_process to continue hangup
08:20:27: TTY5: restoring DTR
08:20:28: TTY5: autoconfigure probe started
08:20:28: TTY3: autoconfigure probe started
08:20:28: %LINK-3-UPDOWN: Interface Async5, changed state to down
08:20:28: As5 LCP: State is Closed
08:20:28: As5 PPP: Phase is DOWN
Thank You
As you can see that the debug
Where interface async 5 (tty5) is keeps on sending outbound LCP packets which are not replied by user (windows pc) so do you see the tx and rx led's on cleint modem flashing during that time?
Or do you see any incomfing packet errors on interface async 5?
For that you need to have "sh interface async x" where x is the modem number involved in that connection. So capture before and after callback connection and see the difference in interface statistics.
Try to use "Async mode dedicated" instead of "interactive" under the async interface
I've tried the async mode dedicated but doesn't work. As you can see I'm using user znoopydog to callback, this isn't a windows user.
Do I need to create this user in windows?
Not sure how user znoopydog works regarding callback..but bottom line is the router's LCP Outbound packets are not replied by user..so after lots of retries, router giveup on that and disconnect the line..
So talk to those concern guys for that..Windows works great for callback.
