I have installed LMS/RWAN at a customer site and I am experiencing two problems:
1. In Campus manager 3.3, the ANI database is not discovering some devices (these devices are in DFM/RME and HPOV) 4 of these devices are 4000/4500 devices with different revisions of 11.2 code and one is a 7010 router also with 11.2 code. I should note however that in the same network there are devices 4000/4500/7010 routers that are being discovered, these also have 11.2 code, but different revisions.
I added the undiscovered devices into RME manually. When synchronizing the essentials db to the ani, these devices are still not added to the ani?
2. In DFM 1.2 updated
, I am receiving a continuous authentication failure alarm for all the 2948 and 5505 switches. When investigating I find that it is not an issue with the SNMP configuration, as I have re-entered these carefully more than once and once again no problems with other applications.
Does any one have any ideas, I am suspecting that IOS and CatOS versions could be causing the problems, but could not find anything concrete.
