Can a C2600 do DHCP for computers on a LAN
I was wondering I know you can do DHCP with a 2600 for SLIp and PPP connections via a router. But can you assign Addresses via DHCP via a 2600 router to computer on the LAN. Much like a NT server would. What we are wanting to do Is seperate one network form another and not have to buy another server just to host DHCP addresses on it. ANy help would be appreciated.
Re: Can a C2600 do DHCP for computers on a LAN
Yes, you will need 12.0.x.T or 12.1 software.
How do I do it. Do i just do the same for a SLIP or PPP. Use a local pool and such. I have looked through the command reference and can find no info on DHCP that is not using PP or SLIP. Any ifo would be great!
That is awesome thanks a million I could not find anything on the subject but that works out perfectly... Thanks again for your help.
164
