Community Member
Can Cisco Works (Small Network Management Solution 1.0 )
Can "Small Network Management Solution" support PIX and Cisco Routers or it is strictly used for Cisco Switches.
I already have CSPM in the network. Can it also manage the Cisco Switches or does it only support Cisco IDS blade for the managment purpose?
1 REPLY
Blue
Re: Can Cisco Works (Small Network Management Solution 1.0 )
SNMS supports the devices listed (including PIX) at: http://www.cisco.com/univercd/cc/td/doc/product/rtrmgmt/cw2000/cwsnms/1_0/cwsmn.htm
Additional devices are supported if you install the IDU 1.0 from:
http://www.cisco.com/cgi-bin/tablebuild.pl/idu10
87
