Can I have an ISDN fail a Frame Relay circuit on a different router.
I am running EIGRP in my network. I have a Frame Relay connection to a vendor via a remote location. I want to be able to set up ISDN dial backup from my location.
Is this possible to basically set dial backup to a remote frame location or do these line have to be on the same router.
1 REPLY
Anonymous
N/A
Re: Can I have an ISDN fail a Frame Relay circuit on a different
Yes, there has to be two physical line on the same router
to be able to use the backup command.
The option opened to you is HSRP betweent he two routers
at you location . One router will be active while the other will
be in standby. The active router will be the one holding you
frame-relay circuit. HSRP will be setup to monitor this frame-relay link
and if it goes down the priority will be reduced
and hence the backup (stanby) takes over as active
R1
int e0
ip add 10.10.10.1 255.255.255.0
standby ip 10.10.10.3
standby track serial 0 40
int se 0
ip add 192.168.253.1 255.255.255.252
encap frame-relay
R2
int e0
ip add 10.10.10.2 255.255.255.0
standby priority 80
username R2-nexthop password cisco
int bri 0
ip address 192.168.254.1 255.255.255.252
dialer map ip 192.168.254.2 name R2-nexthop broadcast 22222
dialer-group 1
encap ppp
ppp authentication chap callin
dialer-list 1 protocol ip permit
85
