Can I insert a new module in a running Cisco3660?
I want a platform which is high available and which is expandable without any power-off or reload.
I read that the Cisco3660 can OIR (online insertion and removal), but I am not sure this means that I can insert a new card into an empty slot so that I can maybe add 4 extra sync-serial ports (NM-4T) to my running system.
If it is not possible which platform do I need for that?
Reason: I cannot stop my network for any additional customer.
Chris
1 REPLY
Re: Can I insert a new module in a running Cisco3660?
OIR is what you need.
Personally didn't know the 3660 was one of them.
The most used for this are the 7200, 7500, 7600, and GSR.
96
