Can I shutdown the switch on CLI? (without touching power button)
Hi mates,
On the 4500 series switch, can I shutdown the switch from command line? (using telnet or console port)
Thanks for helping :)
  • Other Network Infrastructure Subjects
1 ACCEPTED SOLUTION
Re: Can I shutdown the switch on CLI? (without touching power bu
There is no way (either catOS or IOS) to power down a chassis from the CLI. You'll have to have physical access to do this.
HTH,
Bobby
HTH,
Bobby
Silver
The only way I know of to do this is to get a power system that you can access remotelyVarious vendors have them). From this device you can shutdown specific power outlets within that system. That way you can do a cold boot of a device remotely, if needed....
245
