Community Member
Can I use isdn backup interface together with backup load ?
Since using the command backup interface
the bri int is in standby mode, will the backup load still kick in an isdn channel if load on a serial line is above a threshold ?
is q&a 3695 my example or is this backup load only working after the serial line was down ?
1 REPLY
Anonymous
N/A
Re: Can I use isdn backup interface together with backup load ?
NO you cannot. The backup interface command would have already
put the isdn interface into standby and can be used unless
the primary serial interface goes down and the backup isdn kick in.
The backup load and backup interface need to be used seperately.
91
