can not ping local serial interface
i have two router one 3745 the other 2600
the 3745 configuration as follow:
version 12.2
service password-encryption
hostname r2
boot system flash:c3745-is-mz.122-11.T.bin
boot system flash:c3745-is-mz.122-13.T.bin
logging buffered 4096 debugging
enable secret xxxxxx
username xxxx password xxxxxxx
aaa new-model
aaa authentication login default line local
aaa authentication ppp default local
aaa session-id common
ip subnet-zero
no ip domain lookup
frame-relay switching
interface FastEthernet0/0
ip address x.x.0.2 255.255.0.0
duplex auto
speed auto
no cdp enable
interface Serial0/0
ip address 192.168.0.2 255.255.255.0
encapsulation frame-relay
clockrate 2000000
no fair-queue
frame-relay map ip 192.168.0.1 119 broadcast
frame-relay interface-dlci 119
frame-relay lmi-type q933a
frame-relay intf-type dce
interface FastEthernet0/1
no ip address
shutdown
duplex auto
speed auto
no cdp enable
interface Serial0/1
no ip address
shutdown
clockrate 2000000
no cdp enable
interface Serial0/2
no ip address
shutdown
clockrate 2000000
no cdp enable
interface Serial0/3
no ip address
shutdown
clockrate 2000000
no cdp enable
interface Serial0/4
no ip address
shutdown
clockrate 2000000
no cdp enable
interface Serial0/5
no ip address
shutdown
clockrate 2000000
no cdp enable
interface BRI3/0
no ip address
shutdown
no cdp enable
interface BRI3/1
no ip address
shutdown
no cdp enable
interface BRI3/2
no ip address
shutdown
no cdp enable
interface BRI3/3
no ip address
shutdown
no cdp enable
interface Group-Async1
ip unnumbered FastEthernet0/0
encapsulation ppp
dialer in-band
dialer idle-timeout 60
async mode dedicated
peer default ip address pool modem-pool
no keepalive
ppp authentication chap
group-range 129 136
router eigrp 100
network x.x.0.0 0.0.0.255
network 192.168.0.0
no auto-summary
ip local pool modem-pool x.x.0.100 100.0.0.200
ip classless
ip http server
no cdp run
radius-server authorization permit missing Service-Type
line con 0
password xxxxx
line 129 136
flush-at-activation
modem InOut
modem autoconfigure discovery
transport input all
flowcontrol hardware
line aux 0
line vty 0 4
password xxxxx
end
the 2600 configuration as follow:
Current configuration:
version 12.0
service timestamps debug uptime
service timestamps log uptime
hostname router1
enable secret xxxxx.
ip subnet-zero
no ip domain-lookup
isdn voice-call-failure 0
ip address 10.0.0.2 255.255.255.0
no ip directed-broadcast
duplex auto
speed auto
interface BRI0/0
no ip address
shutdown
isdn guard-timer 0 on-expiry accept
interface Serial0/0
ip address 192.168.0.1 255.255.255.0
no ip mroute-cache
no fair-queue
frame-relay map ip 192.168.0.2 119 broadcast
no ip address
shutdown
duplex auto
speed auto
interface Serial0/1
no ip address
shutdown
router eigrp 100
redistribute rip metric 10 100 255 255 1500
network 192.168.0.0
router rip
version 2
network 10.0.0.0
ip classless
ip route x.x.0.0 255.255.255.0 192.168.0.2
no ip http server
line con 0
password shtec
login
transport input none
login
no scheduler allocate
end
they are connected by one serial cable,but i can not ping the 3745 router's local serial interface through the 3745 console.i can ping the 2600's serial interface.
i can not ping the 2600's local serial interface through the 2600 console. i can ping the 3745's serial interface.
i do not know wh
1 REPLY
Re: can not ping local serial interface
You cannot ping your own address on multipoint frame-relay interface, the reason is that there should be a layer2 to layer3 mapping for every destination, now when you ping your own address, the router will not know which DLCI to use to encapsulate the echo request sent to itself. This is normal for multipoint interfaces.
Hope I helped
123
