can not set ethernet port to a specific subnet
I have a Cisco 2610 with one ethernet port. I am trying to set an ip address for ethernet0/0 with /25 subnet, but the system returned error. The details are as follow:
IOS (tm) C2600 Software (C2600-I-M), Version 11.3(10)T, RELEASE SOFTWARE (fc1)
Copyright (c) 1986-1999 by cisco Systems, Inc.
Compiled Tue 01-Jun-99 17:16 by pwade
Image text-base: 0x80008084, data-base: 0x80566960
ROM: System Bootstrap, Version 11.3(2)XA4, RELEASE SOFTWARE (fc1)
System restarted by reload at 13:37:03 utc Mon Dec 8 2003
System image file is "flash:c2600-i-mz.113-10.T", booted via flash
cisco 2610 (MPC860) processor (revision 0x203) with 18432K/6144K bytes of memory
Processor board ID JAD03450604 (3853099489)
M860 processor: part number 0, mask 49
Bridging software.
X.25 software, Version 3.0.0.
1 Ethernet/IEEE 802.3 interface(s)
4 Serial(sync/async) network interface(s)
32K bytes of non-volatile configuration memory.
8192K bytes of processor board System flash (Read/Write)
hostname(config)#int ethernet0/0
hostname(config-if)#ip address 192.168.100.1 255.255.255.128
Bad mask /25 for address 192.168.100.1
Please let me know how to solve the problem.
Thanks for your help.
thavee
1 ACCEPTED SOLUTION
Re: can not set ethernet port to a specific subnet
It doesn't allow you to use 192.168.100.1 because it is part of subnet zero (bit 24 is zero). Configure "ip subnet-zero" and it will work.
Harold Ritter
Sr. Technical Leader
CCIE 4168 (R&S, SP)
harold@cisco.com
México móvil: +52 1 55 8312 4915
Cisco México
Paseo de la Reforma 222
Piso 19
Cuauhtémoc, Juárez
Ciudad de México, 06600
México
Harold Ritter
CCIE 4168 (R&S, SP)
harold@cisco.com
Cisco México
Piso 19
Cuauhtémoc, Juárez
México
It works. Thank you very much for your help.:-)
thavee
220
