Can someone pls help on ospf?
Hi, I post this message some days ago, but not sovled. below is the conversation made:
OSPF area 0 route summarization
fujin.huang - NOC ENGINEER, TMI TELEMEDIA INTERNATIONAL
Nov 7, 2001, 12:43am Pacific
Hi, I found that for the ospf backbone area route summarizaiton, when I use "area 0 range 10.1.0.0 255.255.0.0", it seems not working, the route 10.1.0.0 is not being advertised at all. Any idea on this? Thank you.
jscinocca - NETWORK ENGINEER, FRONTERA CORP
Nov 7, 2001, 6:40am Pacific (1.)
use wild card bits in your mask
Nov 7, 2001, 5:39pm Pacific (1.1)
netmask is correct here. should not be wild card mask.
1 REPLY
Re: Can someone pls help on ospf?
Hello Fujin,
there are a couple of points that I could suggest:
i) make sure that the area id that you specify in the area xx range command, is the area containing the networks that are to be summarized.
ii) in order to advertise the summary route, there must be at least 1 route present in the ip forwarding table that falls within the summary range.
rgds
steve
93
