Community Member
Can't connect to Cisco 1900 Switch with DB9 console port
I am studying towards a CCNA and recently purchased a second-hand 1900 Switch. This is an old model with a DB9 console port, not an RJ45. Consequently, the standard rollover cable in conjunction with a DB9-RJ45 adaptor does not work. When connecting to the port, all I see are AT modem command strings. My research thus far has suggested that these switches require a special pinout configuration for the console cable. Can anyone confirm the pinout configuration so I can create my own cable?
Many Thanks,
Steve.
VIP Purple
Re: Can't connect to Cisco 1900 Switch with DB9 console port
Hello Steve,
check this link for the pinout configuration:
CISCO CATALYST 1900 SERIES SWITCHES
Connectors and Cables
http://www.cisco.com/en/US/products/hw/switches/ps574/products_installation_and_configuration_guide_chapter09186a008007f105.html#xtocid151354
GP
Purple
Save yourself some grief and head to Radio shack and get a db9 null modem adaptor ($5) . Using this with a straight thru cable should get you in . This what I use all the time .
Community Member
I would VERY much like to know how to do this also. I even gone as far to reload firmware (5.37) via xmodem. I can get to the diag menu and have reset factory defaults and console port settings. still get AT commands when trying to continue with startup. I have to assume that if you can communicate with the diag. menu the cabling should be right. I've look at the pinouts in the manual with no luck. I am using a terminal adapter on both ends with a crossover cable and get to the diag fine.
Gary
710
