06-16-2006 10:18 AM - edited 03-03-2019 03:41 AM
I have a pix where I have the "fixup protocol esp-ike" enabled. In this pix, I am trying to set it up as VPN Lan-to-Lan, so the first line I try is "isakmp enable outside", but as soon as I type it, it tells me
ISAKMP cannot be enabled since fixup protocol esp-ike is enabled. Please correct your configuration and re-issue the command
I read that NAT-traversal can perhaps fix this, but I already tried it. I typed "isakmp nat-traversal 3600" and it went OK. I then tried the "isakmp enable outside" again but it gave me the same error message
So I don't know what to do at this point
any help please?
thanks
06-16-2006 11:43 AM
are you using PAT on your PIX by any chance ? If so, both commands indeed are not compatible. Can you post the configuration of your PIX ?
GNT
06-17-2006 03:55 PM
No, PAT is not being used in my pix. Only NAT. My pix 506e acts as a NAT device.
I have read that the 2 commands aren't compatible, so I was asking if there is a work-around that someone can help me with?
thanks
