Webcast-Catalyst9k
Can't ping s0 from ethernet side
I cannot ping the s0 from the ether side of the network. Here is the sh run. Thanks for any suggestions.
phcdme#sh run
Building configuration...
Current configuration : 942 bytes
version 12.1
service timestamps debug uptime
service timestamps log uptime
hostname phcdme
enable secret 5
enable password
memory-size iomem 25
ip subnet-zero
no ip domain-lookup
interface Serial0
description ckt flzc903239mb to dme
bandwidth 256
ip address 192.168.100.1 255.255.255.0
no keepalive
no fair-queue
service-module t1 timeslots 1-4
interface FastEthernet0
ip address 10.1.1.37 255.0.0.0
speed 10
half-duplex
router rip
redistribute connected
network 10.0.0.0
network 192.168.100.0
ip classless
ip route 0.0.0.0 0.0.0.0 FastEthernet0
ip route 192.168.132.0 255.255.255.0 192.168.100.2
no ip http server
dialer-list 1 protocol ip permit
dialer-list 1 protocol ipx permit
banner motd ^CAccess to this router is restricted^C
line con 0
password n10
line aux 0
line vty 0 4
password n9
login
end
Silver
Re: Can't ping s0 from ethernet side
you have no keep set on the s0 , is the line down ? is your CD lead high ?
put the command keep 10 on s0 see if the line goes up
Interface IP-Address OK? Method Status Prot
ocol
FastEthernet0 10.1.1.37 YES manual up up
Serial0 192.168.100.1 YES NVRAM up up
Is this what you are referring to?
Thank you for your help.
I did set keepalive on s0 to 10 and still cannot ping the s0. Thanks.
Silver
can you paste in a sh int s0 and a sh ip route
Silver
no when you disable keepalives , by using the no keepalives command this is what you have done on s0 , the interface will always show up up , you should look at the CD controll lead to determine if the line is up , see below the 'DCD=up' means that the line is up. Does your interface show DCD=up or DCD=down ?
Serial1/2 is up, line protocol is up
Hardware is M4T
Internet address is
MTU 1500 bytes, BW 1536 Kbit, DLY 20000 usec,
reliability 255/255, txload 24/255, rxload 7/255
Encapsulation HDLC, crc 16, loopback not set
Keepalive set (10 sec)
Restart-Delay is 0 secs
Last input 00:00:03, output 00:00:00, output hang never
Last clearing of "show interface" counters 9w6d
Input queue: 0/75/0/0 (size/max/drops/flushes); Total output drops: 2643346
Queueing strategy: weighted fair
Output queue: 0/1000/64/2643346 (size/max total/threshold/drops)
Conversations 0/115/256 (active/max active/max total)
Reserved Conversations 0/0 (allocated/max allocated)
5 minute input rate 43000 bits/sec, 43 packets/sec
5 minute output rate 148000 bits/sec, 44 packets/sec
233426706 packets input, 1639409984 bytes, 0 no buffer
Received 0 broadcasts, 0 runts, 0 giants, 0 throttles
28 input errors, 28 CRC, 0 frame, 0 overrun, 0 ignored, 0 abort
251516916 packets output, 2323636180 bytes, 0 underruns
0 output errors, 0 collisions, 2 interface resets
2 carrier transitions DCD=up DSR=up DTR=up RTS=up CTS=up
Hey guys,
I set the keepalives to 10, tested it and it still wouldn't work, set it back to no and now it is fine.
One other thing, if you don't mind. I can now ping from the 192.168 network, s0 side and e0 side but not an address on the 10.1.1.0. Any ideas why?
Dennis
Silver
can you paste in a sh ip route .
what is the source address and destination address of your ping
deilert,
It goes something like this:
From 192.168.132.2(PC) ping 192.168.132.42 (e0) successful..ping 192.168.100.2 (s0) successful..ping 192.168.100.1 (s0) successful..ping 10.1.1.37 (e0) successful..ping 10.1.1.1-254 (PCs on 10.) unsuccessful.
thanks.
Silver
the subnet mask you are using on your FE is 8 bits , are you using this on the hosts machines ? If you are the pings will not even hit the router they will stay loacl on the segment and will be found by arp requests
Deilert,
I did change the subnet to 10.1.1.0 255.255.255.0. I am still not having any luck. I can ping while on a router, but not from the network side to the s0 side once again. I did a sh int s0 dcd (and everything else) is up. Suggestions?
Dennis
Silver
You did not give the config of the router at the other end of the link. This could be useful. Try removing the redistribute connected though. Guess it is confusing the RIP. What are you using at the other end, RIP or static, check for missing routes i.e if RIP, that all necessary interfaces are specified, for static, all routes are defined.
Silver
Where is the subnet 10.1.1.1-254 located ? does it hang off the FE with the 10.1.1.37 255.0.0.0 ? Are there any other routers between ?
Can you past in a sh ip route from this router ?
119
