Webcast-Catalyst9k
cannot ping serial interface when move configuration from c3662 to c7206
There are 4 serial links on Cisco 3662,the configuration is just so simple
and there are some access-list.
When I stop using Cisco 3662 and move all 4 serial links to Cisco 7206,
and then interfaces are up,and apply all access-list, and then test ping,
cannot ping ip on any serial interfaces,but after remove access-list applying
from any interfaces, i can ping all ip on all 4 serial links
although i can ping any serial interfaces on all link on Cisco3662 with access-list applying.
1 REPLY
Re: cannot ping serial interface when move configuration from c3
if u could paste the configs, (how it looks on either routers), it would be great to analyze, whats going on.
100
