Yes, I had the same problem with the new blades.
Load the new Cview pacakage and will fix the problem.
Download the cv5packages.zip file, which contains Cat6000.cv50.v5-0.zip and the dependent device packages
CLIParser.cv50.v1-3.zip, SwitchAddlets.cv50.v1-17.zip and Entity.cv50.v1-3.zip, from Cisco.com.
Make sure you do get the CatQDM as well.
Note: With CiscoView 5.3 or later, CatQdm.cv53.v1-7.zip or later will also be available
in cv5packages.zip
Hope this helps.
