Webcast-Catalyst9k
cat 2940 ACS problem Version 12.1(22)EA6
I have 2 2940 Version 12.1(22)EA6 that after i put int the tacs+ commands it will not let me back into the switch from anywhere. When I try to login in it tells me that the password is wrong, when i know it is correct.
1 REPLY
Re: cat 2940 ACS problem Version 12.1(22)EA6
Can you paste the relevant TACACS+ config commands taken from your switch here ?
Also are you seeing any kinda logs in your syslog server or in ur switch related to the access attempts ?
regds
121
