03-06-2006 05:36 AM - edited 03-03-2019 02:08 AM
trying to copy the IOS to a tftp server this is the output i'm getting any idea what i'm doing wrong?
Directory of flash:/
2 -rwx 0 Jan 01 1970 00:02:15 +00:00 env_vars
3 -rwx 344 Jan 01 1970 00:02:15 +00:00 system_env_vars
4 -rwx 3685 Jun 11 1993 19:22:59 +00:00 config.text
5 -rwx 5 Jun 11 1993 19:22:59 +00:00 private-config.text
8 drwx 192 Mar 01 1993 00:05:57 +00:00 c3550-i9q3l2-mz.121-22.EA
a
15998976 bytes total (8989696 bytes free)
PRKSW01_GF#copy flash tftp
Source filename []? c3550-i9q3l2-mz.121-22.EA1a
Address or name of remote host []? 1.0.84.205
Destination filename [c3550-i9q3l2-mz.121-22.EA1a]? c3550-i9q3l2-mz.121-22.EA1a
%Error reading flash:c3550-i9q3l2-mz.121-22.EA1a (Is a directory)
PRKSW01_GF#
kind Regards
J mac
Solved! Go to Solution.
03-06-2006 05:42 AM
You are using image built from a tar file.
Try to following commands:
#cd flash:/c3550-i9q3l2-mz.121-22.EA1a/
#dir
#copy c3550-i9q3l2-mz.121-22.EA1a.bin tftp
Leon
*Please rate useful posts
03-06-2006 05:42 AM
#dir
Leon
03-06-2006 05:46 AM
You can also create an archive and download it to your tftp server.
# archive tar /create tftp:192.168.1.1/c3550-i9q3l2-mz.121-22.EA1a.tar flash:/c3550-i9q3l2-mz.121-22.EA1a
03-06-2006 06:07 AM
it worked great.
thanks alot
