08-28-2002 06:30 PM - edited 03-02-2019 12:59 AM
We faced one issue about the Cisco 4006 - when we connected the 2600 ethernet port (10mega) to the 34 port module WS-X4232-GB-RJ, the network will be down after a while, routing ttl timeout and some ports dropped off. When connect the router port (2611) back to WS-X4148-RJ, it's ok.
Anyone has suggestion? Thanks!
Version information -
Copyright (c) 1995-2000 by Cisco Systems, Inc.
NMP S/W compiled on Sep 30 2000, 12:25:52
GSP S/W compiled on Sep 28 2000, 18:28:28
System Bootstrap Version: 5.4(1)
Hardware Version: 3.2 Model: WS-C4006 Serial #: JAB0525073Y
Mod Port Model Serial # Versions
1 2 WS-X4013 JAB0525073Y Hw : 3.2
Gsp: 6.1(1.0)
Nmp: 6.1(1)
2 34 WS-X4232-GB-RJ JAE0506023H Hw : 2.3
3 48 WS-X4148-RJ JAE054302L5 Hw : 3.0
4 48 WS-X4148-RJ JAE054302J6 Hw : 3.0
5 48 WS-X4148-RJ JAE054302KE Hw : 3.0
6 48 WS-X4148-RJ JAE054302LM Hw : 3.0
DRAM FLASH NVRAM
Module Total Used Free Total Used Free Total Used Free
1 65536K 33046K 32490K 16384K 4753K 11631K 480K 260K 220K
08-28-2002 07:25 PM
Do you see any port errors? swap slots with a another slot and see if the problem stays with the slot or follows the module. Also you are running the first release in 6.x..I suggest that you upgrade to 6.3(8) which has fix for many bugs including the ones discussed in the following field notice
08-28-2002 07:25 PM
08-28-2002 07:25 PM
