Cat.4006 - Web Based Management Console ???
Hi anyone pls clarify as I have a Cat.4006 with a Supervisor Eng. II and a 6-port Fiber Module installed.
I have configured an IP address to it by the following command;
console>(enable)set interface sc0 10.0.1.1 255.0.0.0 10.0.1.255
When I used my IE from another workstation to connect to the Cat 4006 by using its IP address configured as above, the IE shows a help page to link to the following help URL;
www.cisco.com/cco
and it 's never showing the Switch WEB BASED MANAGEMENT Page. Why is it so ? Anything wrong with my IP configuration above ?
Please help out.
thank you.
Re: Cat.4006 - Web Based Management Console ???
You might want to additionally give the following command,
set ip http server enable
Use show ip http for verifying the configuration.
Hi Sir, I did have specified the command "set ip http server enable" in the Cat.4006.
How do I confirm the IOS run by the Cat.4006 ? As I understand, the Cat.4006 might be running the Cisco Integrated IOS (Native Mode) or CatOS.
When do I need to configure the Management Ethernet Interface (me1) ?
Please help out.
For the cat 4000, cisco doesnt ship the Catalyst web interface bundled in the Image.The CWI (cat web int) is a totally separate image that needs to be downloaded. Check software center at cisco to download the image. Hope this is of help
http://www.cisco.com/univercd/cc/td/doc/product/lan/cat6000/cfgnotes/78_10697.htm#xtocid0.
Sup2 cannot run native IOS. So I belive you have Sup2. To enable web interface, you also need cv image in the bootflash. The following page should help
http://www.cisco.com/warp/public/473/105_15954.shtml
323
