CAT 5005 - SUPIII Console Port Problem
Hi All,
I got a Cisco 5005 switch and I have connected myself to the Console port and then connected myself to my lappy witha terminal end. I went on hyperterminal with a 9600-8-N-1 and the console is not comin up.
any help plese.
thx
venu
  • Other Network Infrastructure Subjects
1 REPLY
Re: CAT 5005 - SUPIII Console Port Problem
Sup3 Engine needs a Straight through console cable. What kind of console cable are you using? If you are using normal flat roll over cable, you'll need a straight through cable
88
