Cat 6000 and 720 sup engine
mayberr
How do we get the MSFC3 to be seen by the switch?
Doing a show mod shows the sup eng but not the MSFC. In
the older sup 1 you could get to the MSFC with the
sessions comand. Doing session command with sup 720 we
get "module not installed". Thoughts anyone ?
jc.cisse
Your MSFC3 may be on ROMMON. Connect a terminal on the console port and do the following:
"switch console"
that should take you to the ROMMON prompt. From there issue the "boot" command and that should get you going.
