You may experience some slow load times, errors, and slight inconsistencies. We ask for your patience as we finalize the launch. Thank you.
Cat 6000 and 720 sup engine
How do we get the MSFC3 to be seen by the switch?
Doing a show mod shows the sup eng but not the MSFC. In
the older sup 1 you could get to the MSFC with the
sessions comand. Doing session command with sup 720 we
get "module not installed". Thoughts anyone ?
  • Other Network Infrastructure Subjects
1 REPLY
Re: Cat 6000 and 720 sup engine
Your MSFC3 may be on ROMMON. Connect a terminal on the console port and do the following:
"switch console"
that should take you to the ROMMON prompt. From there issue the "boot" command and that should get you going.
95
