Bronze
Cat 6500 Supervisor Engine 2 Memory Installation
Autoboot hangs, and I quess its because
i have to uppgrade switch memory.
I have upgraded Route Processor memory,
but i cannot find were the memory for the switch processor is located.
Is it same type of memory: MEM-S2-XX
Anyone ?
Regards Bjornarsb
1 REPLY
Re: Cat 6500 Supervisor Engine 2 Memory Installation
Hi Friend,
Have a look at this link which will guide you how to install bootflash on supervisor engine
http://www.cisco.com/univercd/cc/td/doc/product/lan/cat6000/cfgnotes/78_12667.htm#27709
HTH, if yes please rate the post.
Ankur
105
