Webcast-Catalyst9k
CAT 6509 problem when I configure SRM
Problem Description: one channel of 2 port etherchannel shows connected at one end of a link only. checked both GBICs and Fibre. All seem OK. This error occured after attempting to install Redundant MSFC2. The following procedure was followed
1) Inserted second supervisor module
2) in switch config mode entered "set sytem high availibility enable"
3) session 15 to supervisor
entered commands
redundancy
High Availibilty
single router mode
exit from session 15
4) session 16
entered redundancy
high availibility
single router mode
recieved message that configiuration in module 15 had not been saved
exit from session 16
5) session 15
entered "wr m"
6) session 16
reload
AT this point we noticed that the 6509 containing the newly inserted redundant supervisor showed port 1/1 (port 1 of the etherchannel) "not connected"
corresponding link on other 6509 showed connected.
diabled and enabled port 1/1 on the 6509 with the link down. This caused erratic performance on the link, and th eport still showed down.
We physically removed the fiber and performance returned to normal.
We then removed the newly inserted failover supervisor, but the problem remains the same.
Attached is a log file of sh tech commands from both 6509's plus thier assosciated session 15 rouyting module.
1 REPLY
Re: CAT 6509 problem when I configure SRM
Often times complex troubleshooting issues are best addressed in an interactive session with one of our trained technical assistance engineers. While other forum users may be able to help, it’s often difficult to do so for this type of issue.
To utilize the resources at our Technical Assistance Center, please visit http://www.cisco.com/tac and to open a case with one of our TAC engineers, visit http://www.cisco.com/tac/caseopen
If anyone else in the forum has some advice, please reply to this thread.
Thank you for posting.
147
