Attention: The Community will be in read-only mode on 12/14/2017 from 12:00 am pacific to 11:30 am.
During this time you will only be able to see content. Other interactions such as posting, replying to questions, or marking content as helpful will be disabled for few hours.
We apologize for the inconvenience while we perform important updates to the Community.
Cat OS vers.7.2 for Calalyst 6509
Can I use this software for Layer 3 switching and OSPF as IP routing protocol?
Thanks very much
Re: Cat OS vers.7.2 for Calalyst 6509
Yes you can - but you also need and MSFC as well - and that is where the IOS portion of the software should be loaded. The 7.2 software is for the switch portion only.
If you do not need the features of 7.x train, latest 6.3(x) should be a good/stable code to run on the Sup. And you need an MSFC for layer 3 features as Bradley mentioned
98
