Cat1900 and Port Mirroring / Switched Port Analyzer (SPAN)
juergen.fischer
Is it possible to mirror a port on a Catalyst 1900 Series Switch ?
Which IOS is needed and can you post a configuration example please.
Juergen
tsettle
Level 3
Level 3
You can do SPAN on the Cat1900. Here is a link to config guide that walks you through the config menu for this feature.
http://www.cisco.com/univercd/cc/td/doc/product/lan/28201900/1928v9x/19icg9x/19icoutb.htm
In looking at the docs it appears all version 6.x - 9.x support port monitoring on the Cat1900.
tsettle
Level 3
Level 3
