Cat3548xl Output Buffer Failures/Overruns
sknorr
I have users that are timing out of our imaging application. This only happens to users connected to the same switch. This is the only switch with ports that are receiving output buffer failures. Also, the number of buffer failures is identical to the number of underruns. I don't know how to start troubleshooting this. I tried the sho buffer command but I don't think that is helpful. I guess my question is what could the bufferfailures mean? What should I be looking at?
FastEthernet0/3 is up, line protocol is up
Hardware is Fast Ethernet, address is 0006.288c.ae83 (bia 0006.288c.ae83)
MTU 1500 bytes, BW 100000 Kbit, DLY 100 usec,
Keepalive not set
Auto-duplex (Full), Auto Speed (100), 100BaseTX/FX
Last input never, output 00:00:01, output hang never
Last clearing of "show interface" counters 2d01h
Queueing strategy: fifo
Output queue 0/40, 0 drops; input queue 0/75, 0 drops
51928 packets input, 8101226 bytes
Received 645 broadcasts, 0 runts, 0 giants, 0 throttles
0 watchdog, 0 multicast
394883 packets output, 77720160 bytes, 217 underruns
0 lost carrier, 0 no carrier
217 output buffer failures, 0 output buffers swapped out
deilert
Level 6
Level 6
If you place the output in the output interpretter
https://www.cisco.com/cgi-bin/Support/OutputInterpreter/parser.cgi/tmp
it shows
Interface FastEthernet0/3 (up/up)
WARNING: Interface FastEthernet0/3 is up/up but keepalives are not set (set to 0 secs)
so the interface could be spoofing.
TRY THIS: Set the keepalive timer to an integer value using the 'keepalive'
interface configuration command. The default is 10 secs.
WARNING: The counters are older than 24 hours and may not accurately reflect
the current status of this interface.
TRY THIS: Reset the counters using the 'clear counters' command and wait a few
minutes to resubmit the output to Output Interpreter.
WARNING: There are 1 or more reported underruns.
This indicates the number of times that the transmitter has been running
faster than the router can handle.
TRY THIS: Monitor the level of underruns over time. If they continue
increasing, consider buffer and queue tuning or upgrading hardware.
REFERENCE: For further information, see: Troubleshooting Ethernet and
Buffer Tuning
INFO: There are 1 or more reported output buffers failures.
If outgoing interface buffers are not available, an output buffer failure is
reported. If an interface buffer is available but the Transmit Queue Limit is
reached, the packet is dropped. However, if 'transmit-buffers backing-store'
is enabled, the packet is placed in a System Buffer (which has to be obtained
from an appropriate Free-List), and enqueued in the Output Hold queue for
future transmission at the Process level, and an Output Buffer Swap is reported.
You may also want to hard code your speed and duplex settings. also ensure you set keepalives as stated above
hope this helps
