Webcast-Catalyst9k
Cat4506 port-security and Mac G5 problem
Has anyone heard of falsely port-security mac violation messages? We'd recently installed some new Cat4506 switches and have port-security enabled. Allowing 1 mac per port and age out 10 mins of inactivity. This works very well with Windows platform PCs. When a Mac G5 is plug into a port previously has a PC or another Mac, it triggers a mac violation message. The G5 is unable obtain a DHCP address. "Show port-security" on the switch does not reveal any violations. The G5 required several reboots in order to obtain a valid address. The ports are also DHCP snooping enabled. Don't think that's the problem, cause "mac violation" messages are clearly port-security related.
switchport mode access
switchport port-security
switchport port-security aging time 10
switchport port-security violation restrict
switchport port-security aging type inactivity
spanning-tree portfast
ip dhcp snooping limit rate 100
Re: Cat4506 port-security and Mac G5 problem
If possible, disable the Spanning-tree and check if it works OK
Thanks for responding. Have the same problem with spanning tree disabled. Any other ideas?
91
