cat4507R can't recongnize supervisor II plus, help
I have a cat4507R with redundant supervisors (two Ws-X4013+). Now all STATUS LEDs stay off. the switch can't recognize the supervisors and line cards.
VIP Purple
Re: cat4507R can't recongnize supervisor II plus, help
can you check if you are running the minimum required software ?
S4KL3-12119EW
Cisco IOS Software for Supervisor Engine II-Plus and IV; basic Layer 3 software image (RIP, static routes, IPX, AppleTalk)
GP
Thanks for your response. I don't think I provided the details. At first, the switch worked well. Then I removed the supervisors from the slots separately to test the function of redundant supervisor. After that, the supervisors were disabled. I'm sure the supervisors are without any damage. I remembered maybe it run cat4500-IOS-12.1 software.
Can you console in and see what is going on. Sup2+ is supported from 12.1(19)EW
http://www.cisco.com/univercd/cc/td/doc/product/lan/cat4000/relnotes/ol_2170.htm#392226
Thanks for your response. I think I should give your the details. At first, the switch run well. then I removed Sup2+ separately to test if the redundant Sup worked well. after that the Sup2+s were disabled. I'm sure without any damage on Supervisors. Now, no information was showed from console.
111
