Cat6513/Need to send traps to a port
How can I send traps generated from Cat6513 using Catos 6.2.2 to a specific IP address and a specific port ?
Re: Cat6513/Need to send traps to a port
I'm not familiar with the cat6513, but on the IOS based switches use this:
Router(config)# logging on
Router(config)# logging trap informational
Router(config)# logging 192.168.16.3 (use target IP)
The cat version should be quite similar.
set logging ? - will show you all of the logging commands.
set snmp ? - will show you all of the snmp commands. The set snmp targetaddr command is where you set the address of your monitoring station.
Thanks, following command worked for me on cat6513 release 6.2(2) :
set snmp targetaddr param snmpV1TrapParams udpport taglist snmpV1Trap
124
