Bronze
Cat6K Sup720 - PBR on specific interface
G'day,
I'm trying to get PBR working for a specific interface (gi x/x) rather than a whole vlan.
I know this is possible on other platforms but i'm kinda stuck :(
Current version is....
12.2(18)SXF4
Any tips would be great!
Andrew
1 ACCEPTED SOLUTION
Silver
Re: Cat6K Sup720 - PBR on specific interface
Yes, minimize the ACL will also lower the router's resource to process the ACL. i.e. hit the rule earlier.
Silver
What I suggest if you have the hardware on hand, just try to enter the config, if it accept then there should be no problem.
If it can't, you may configure a dedicated VLAN for the GE then PBR to this VLAN is the same. You cannot PBR traffic to a trunk and even you PBR to a physical interface, it should be in access mode.
Hope this helps.
Bronze
G'day,
It looks like I cant run it on a switchport :-( ...
It is currently setup via a vlan but I would have like a little extra granularity with hosts would be PBR'd without using ACL's.
Ohh well, ACL's it is then!
Thanks Jack!
CHeers
Andrew
Silver
You're welcome. If the traffic will be PBR'ed then it should be using ACL, otherwise, how do you determine which traffic is require to redirect ? ;)
Bronze
yeah, I only wanted a single acl for each "application (tcp any eq 80 any)" to minimise the amount of acls..
Ohh well... one acl for each server will have to do!!
Silver
222
