Catalyst 2948 port speed
We have a Catalyst 2948 with 6 VLANS configured. There is a statement in the config that states: set port speed 2/1-48 10. All of the ports I have used so far have been all 10 meg. Now I need to set port 18 to 100 meg. How do I do this and what commands are used so it doesn't affect the other 10 meg ports?
Thank you.
Silver
Re: Catalyst 2948 port speed
carol
set port speed 18 100
This will set the speed of port 18 to 100Mb
the config will be adjusted dynamically
You also need to reset the port to change the setting
What is the command to reset only port 18 or do I need to reset the switch?
Thanks again!
Silver
to disable
set port dis mod/port
set port en mod/port
186
