Catalyst 2948G and 2948G-L3
I'm trying to get working both switches but i can't do that to nothing whit them, not even between 2 simple switch port. In my L3 switch can't create vlan's, can't get access to web management, and with 2948G with CatOs equal.
I've tried some example configurations that are on Cisco site but ... nothing.
Can anyone help?? IOS?not last one but the one before that.
NOTE:The basis is that i 'just' need to put working 48 switch port's, and possibly put both communicating between them with a crossover cable.
1 REPLY
Silver
Re: Catalyst 2948G and 2948G-L3
Take a look at the software configuration guides in detail before trying to get started. Even if all you want to do is configure a few ports, you will be best served by reading through the following documents:
2948G
http://www.cisco.com/univercd/cc/td/doc/product/lan/cat5000/rel_6_1/quick_sw/index.htm
2948G-L3
http://www.cisco.com/univercd/cc/td/doc/product/l3sw/4908g_l3/ios_12/18w522a/config/intf_cfg.htm
195
